sherridge101
export to Flash issue
Apr 17, 2012 9:29 AM
Hi all,
We've created several comps with imported illustrator documents, and these export to the Flash player as scalable vectors fine.
However, if we import one of these comps into the other, and then export this, the exported Flash file has the original comp as vector but the imported comp part as pixelated.
I hope that make sense.
Cheers,
Steve
    Apr 17, 2012 10:17 AM   in reply to sherridge101
    It works as designed - only root level stuff is exported as vectors. Nesting/ symbols are not supported.
    Mylenium
    Apr 18, 2012 1:52 AM   in reply to sherridge101
    You could copy&paste everything together in one comp. Other than that you could use Flash and Flash Catalyst to assemble multiple existing SWFs...
    Mylenium
