I have tried to install CS$ Design Premium about 8 times! Keep getting, "error as UninstallColorProfilesRollback and referred me to kb403891". I have tried Solution 4 times. Does not help. Finally clicked, "continue" installation, and it appears to have installed "with errors"; "you may not have full functionality"... message. Can anyone help?
Hi Jtown,
Lets go ahead and try the below suggestions and check if that helps.
Solution 1: Rename the following files:
C:\Program Files\Common Files\Adobe\caps\pdb.db
C:\Program Files\Common Files\Adobe\caps\Media_db.db
Make sure you dont touch caps.db under the same folder. Now run the installer again and check.
Solution 2: Give full permissions to the below locations:
C:\Windows\System32\Spool\Drivers\Color
C:\Program Files\Common Files\Adobe\Color\Profiles
C:\Program Files (x86)\Common Files\Adobe\Color\Profiles
C:\Program Files\Common Files\Adobe\Color\Settings
C:\Program Files (x86)\Common Files\Adobe\Color\Settings
C:\Users\[username]\AppData\Roaming\Adobe\Color
C:\Users\[username]\AppData\Local\Adobe\Color
Cheers!!
Arpit
