trying to print a white box at 85% transparent over a background image. The white box is set to 85%, normal transparency. Pdf is created and the white box disappears. I tried several different adjustments with knock out but can't get the white box to stay!
I was adjusting the opacity through the effects window/tools....
This is the screen shot from INDESIGN file and how the file is set up..... the effect opacity level was set at 85%
This is how the the hi-res pdf was exporting from InDesign and I have all attributes check and nothing is set to overprint....
and this is what the pdf SHOULD look like.....
****and I had to sit there and mess with this pdf FOREVER.... and how I was finally able to export the pdf properly was by using a different PDF export option...
The printer I use has a set profile that I am suppose to use for the pdfing of the final hi-res pdfs to be uploaded to the press....
But when I went and used the pdf-x-1a option it was fine.
Does any one know which setting in the pdf profile that would have affected the opacity to not carry over???
I am going to email the printer directly to see what they have to say and possibly suggest making the correct adjustments so this does not happen in the future....
It's solely on a case-to-case basis.
I'd like you to answer a few questions to enable us come up with the reason for your PDF not printing without setting to PDF-X-1A option:
1. Are you using Mac OS?
2. Is your PDF printer the default Mac OS install or do you have Acrobat Pro installed as well?
3. Is your indd document CMYK or RGB colorspace?
4. If it is CMYK, have you set custom options for overprint colors?
By default, 'white' is not an overprint compatible color as there is no printer that 'prints white'. If/ When you choose to 'overprint white', you instruct InDesign that you want white 'knocked out'. This may possibly be a reason as if white is set as a custom overprint color, it may not appear in your PDF/ final print output.
Have you by any chance grouped the 'white' layer with other layers? If yes, do you have any other custom knockout/ overprint set to your other elements of the group?
