I am trying to import plant photos into Lightroom4 with their Family, Genus and Species along with Location keywords, by placing the data in the image using exiftool. But failing. One hierarchy seems to work, but not more. I can replicate what Lightroom creates, but it does not seem to read OK.
The problem is not really the exiftool command: rather that I have been
trying various combinations of exif data to create hierarchical keywords
on import.
I am using
exiftool -csv=test.csv .
with one image, and various contents of the HierarchicalSubject of the
csv file. I check what I have created using
exiftool IMG_0016.JPG | less
I added keywords within Lightroom and saved the metadata to see what it
wrote: it seemed to be HierarchicalSubject, Subject and Keywords. But I
seem to need just HierarchicalSubject when I import.
If I define keywords Big and small within Big, and create
HierarchicalSubject: Big|small
then on import I get the hierarchical keyword OK. But if I try to also
set up Big2|small2, by using
HierarchicalSubject:Big|small, Big2|small2
I get a single keyword small2 nested in "small, Big2", nested in Big.
I think you're encountered two issues that aren't very well documented:
- You need to set the Subject field, not HierarchicalSubject, with the keywords of the form "Big|Small" and leave HierarchicalSubject blank. LR will properly interpret on import the "|" character in the Subject field. (LR will only interpret "Big|Small" in HierarchicalSubject if Subject also contains "Big, Small".)
- You need to provide the -sep option to Exiftool when reading a CSV file:
Note that there is a space after the comma. The Exiftool command-line documentation says that is the default for the -sep option, but it doen't appear to be the case.
Very many thanks. I used -sep ", " (without the =) and it worked.
It seems to work with either the HierarchicalSubject or the Subject
field set in my tests, but
-sep ", " with a space was necessary because I had a space in my csv
file. Without this space I needed -sep "," rather than -sep ", ".
My problem was that I did not understand the significance of the + in
string+ in the exiftool description of the Subject tag. And I did not
ask for a binary display, so I could not distinguish between one or two
keywords.
shows it quite clearly.
BTW I think -sep is necessary for csv file input but not when list data
are entered from the command line. But the help is not very clear.
The documentation states that ", " is the default for reading. The default for writing is to not split the value, but I admit this isn't perfectly clear.
- Phil
