Hey all, My repeat region looks fine in all browsers except IE7. For some reason the 5th product onwards seems to have a bigger top margin (about 20px), which pushes the columns down. My code is valid and I've checked CSS and stray DIVs etc. I really don't get it as if the problem was with the repeated container DIV, surely it would affect every DIV? Can anyone shed any light? Here's the page and a snapshot below of the problem. thanks http://goo.gl/5rlgc
I doesn't look like a human being wrote this markup. Was this markup generated by some kind of Web application (to put it kindly)?
Here's something that should work for IE 7. You should clear your floats for each line of images. So, first add the following rule to your stylesheet:
.spacer { clear: left; }
Each Image is wrapped in a div with a "productWrap" class. So, after the last one in each row, add the following div:
<div class="spacer">
So, for example, in the first row the last image is Alexia Couture. It's wrapped in the following productWrap div:
<div class="productWrap">
<img src="upload/03.jpg" alt="" class="image">
<input name="ref" type="hidden" class="ref" value="03" readonly="readonly">
<input name="description" type="hidden" value="Stunning strapless wedding gown, with crystals and diamantes. The corset tie back has buttons running all the way down the back to the bottom of the train. A small bow with long ties can also be attached to the back." readonly="readonly">
<div class="title1"><input name="formTitle" type="text" class="titleClass" value="Alexia Couture" readonly="readonly"></div>
<div class="price1"><input name="formPrice" type="text" class="price" value="£ 395" readonly="readonly"></div>
<div class="size1"><input name="formSize" type="text" class="size" value="Size 8-12" readonly="readonly"></div>
<div class="zoom2"><input name="submit" type="button" value="" class="zoom zoomProduct" id="zoomProduct3"></div>
</div>
I included all the code between the opening div and the closing div for the productWrap class and then I added the div with the spacer class after the closing div for the productWrap..
Add that line (the last one that I bolded) after the last productWrap div for each row and that should remedy your space problem.
Now that I think about it, I don't know if a table is the solution because you are not repeating rows of information. I'd have to give this more thought. Unfortunately, I have three classes I have to teach Thursday, Friday, and Saturday. After Saturday, if you haven't come up with solution, I will be able to give this some thought. It would be helpful if you can post the php code for the repeated regions.
It's just what Dreamweaver inserts when I selected repeat region from the data objects menu, with a counter to stop duplicate IDs. By the way, I appreciate my code may not be perfectly structured.
<?php
$counter = 0;
do {
$counter++;
<form action="zoom.php" method="post" name="form<?php echo $counter; ?>" id="form<?php echo $counter; ?>">
<div class="products">
<img src="upload/<?php echo $row_Recordset1['ref'];?>.jpg" alt="" class="image">
<input name="ref" type="hidden" class="ref" value="<?php echo $row_Recordset1['ref']; ?>" readonly="readonly">
<input name="description" type="hidden" value="<?php echo $row_Recordset1['description']; ?>" readonly="readonly">
<div class="title1"><input name="formTitle" type="text" class="titleClass" value="<?php echo $row_Recordset1['designer']; ?>" readonly="readonly"></div>
<div class="price1"><input name="formPrice" type="text" class="price" value="£ <?php echo $row_Recordset1['price']; ?>" readonly="readonly"></div>
<div class="size1"><input name="formSize" type="text" class="size" value="Size <?php echo $row_Recordset1['size']; ?>" readonly="readonly"></div>
<div class="zoom2"><input name="submit" type="button" value="" class="zoom zoomProduct" id="zoomProduct<?php echo $counter; ?>"></div>
</div>
</div>
</form>
<?php } while ($row_Recordset1 = mysql_fetch_assoc($Recordset1)); ?>
I've stripped the whole page back and the problem seems to be with the form being inside the repeat region. The code below causes the alignment problem in IE7 from container six onwards and can be seen here http://goo.gl/BVjYv. If I remove the form surrounding the productWrap DIV, the alignment problem goes away. Does IE7 not like forms inside repeat regions or have I made a stoopid mistake somewhere? Thanks again
<div id="wrapper">
<?php
$counter = 0;
do {
$counter++;
<div class="productWrap"></div>
</form>
</div>
OK, I got it. Form should be inside the productWrap DIV not surrounding it. Really didn't think it would be something so simple especially since it was fine in other browsers. Thanks for your help J Cellini
