brkofdon
Eyedropper Current Layer sampling problem.
Apr 17, 2012 12:15 PM
Tags: #photoshop #color #picker #eye_dropper_problem #eyedropper #cs5.1 #eyedropper_tool
Using the "current layer" sampling setting for the eye dropper before I apply any top layer adjustments (adding a top layer with a different blending more or adding an adjustment layer) it works fine. When I use any adjustment layers or any layer that has a blending mode, it affects the way the eyedropper picks color especially when set to current layer.
For instance, If I paint a new blank layer with random colors, I create a black and white adjustment layer on top of that one, I select the first color layer I go to pick a color using the eye dropper with the current layer sampling set, it picks a grey color (which is wrong). BUT!! if I open up the color picker with the color layer selected it picks the correct color. Now, if I delete the black and white adjustment layer, and I am back to only having the color layer, I then go to pick a color with current layer sampling still set, it chooses a grey color again?!?! There are no more layers on top of the original color layer I painted first, and yet it chooses a grey color?!?! I hope this makes sense, any ideas on why this is happening?
I am working on Photoshop CS5 12.1 64bit
    Apr 17, 2012 11:01 PM   in reply to brkofdon
    Could you please post a screenshot with the pertinent Panels visible?
    Apr 18, 2012 2:50 AM   in reply to brkofdon
    Curiously I could reproduce the behaviour in CS5 (12.0.4 on Mac OS 10.6.8) once, but not anymore.
    And in the CS6 public beta it seems to work as expected right away.
    Jun 2, 2012 5:09 AM   in reply to c.pfaffenbichler
    I'm having the same problem in CS5.
    With current layer selected and a not visible layer of curves (contrast) and trying to pick from the current layer it picks as if the curves layer was visible.
    I have attached 2 images: first trying to pick with the curves layer off (you can see that it's picking a black color where brown should be picked. Second one with the curves layer on.
    After restarting Photoshop every thing work fine again. So I have assumed that the problem is vinculated with the action done before:
    1. Duplicate image 2 times
    2. Gaussian blur of 6px to the first image
    3. Apply image of the gaussian (RGB channel) inverted in mode "Add", scale 2, displacement 0.
    4. And I create a group as you can see on the screen shots.
    http://www.youtube.com/watch?v=wh6eIyrzbt0&t=1m8s
    I can reproduce this issue every time I use this technique...
    Jun 3, 2012 1:17 AM   in reply to estmargue
    I can reproduce this problem with a simple image too and just opening a curves adjustement layer.
    If I restart photoshop, all is fine again, until I open the curves layer and try again to use the color picker... ¿Any idea to solve this problem?
    Jun 3, 2012 1:48 AM   in reply to estmargue
    Ok, I have tried it on the windows version and it doesn't happen.
