Marit_SR
Can I build website in MUSE and administrate in JOOMLA?
Apr 18, 2012 8:05 AM
Anybody know if this works together?
    Apr 18, 2012 8:53 AM   in reply to Marit_SR
    This is not possible in Muse and it is unlikely that Adobe will offer such an option when they'd prefer you to use their own Business Catalyst CMS.
    You might try http://www.artisteer.com/ to build templates/themes for Joomla and then use Joomla extensions to add design elements and functionality.
    Apr 18, 2012 8:56 AM   in reply to Marit_SR
    You can export the Muse web site as HTML and then upload it on any web host using any FTP client.
    The process to use an ftp client is described in the following article: http://www.adobekb.com/using_3rdparty_ftp.html
    Apr 18, 2012 10:26 AM   in reply to Marit_SR
    CMS features will not be part of the Muse 1.0 release. We intend to add CMS features to Muse in the future that will work with Adobe's Business Catalyst platform. Business Catalyst already has CMS features (see http://www.businesscatalyst.com/product-tour/overview for more info), but Muse isn't yet able to take advantage of them natively.
    Apr 18, 2012 10:33 AM   in reply to Corey@Adobe
    Did NorthCape1 or Corey mark this topic as "answered"?
    Usually the OP  is best at flagging a topic as answered, if they truly believe their question was answered.  ...at least that is how it typically works in Adobe's Jive forums.
    Apr 18, 2012 10:54 AM   in reply to Marit_SR
    NorthCape1 wrote:
    ...I understand that I can export the site as html...
    Abhishek Maurya misled you by saying that you can export "as HTML and then upload it on any web host using any FTP client". They apparently do not understand what Joomla is.
    The HTML that you export from Muse is a bit of a mess. You would need to be an advanced web designer to make sense of Muse's output and modify it for use in Joomla or any other CMS.
    NorthCape1 wrote:
    I did mark it as helpful...
    I was not fishing for you to mark my post as helpful or as an answer. I was just confused how Corey's post was flagged as the correct answer as soon as he posted it.
    Apr 18, 2012 12:39 PM   in reply to Marit_SR
    Joomla has its own menu system and "widgets" so you should not bring either of those over from Muse to Joomla. That leaves very little need to use Muse.
    Here's how to make a Joomla template:
    http://docs.joomla.org/Creating_a_basic_Joomla!_template
    Apr 19, 2012 1:51 PM   in reply to Marit_SR
    May 6, 2012 2:57 PM   in reply to Marit_SR
    Sure you can, but it's a manual processs. All you have to do is export your website to a folder and then, you will have the hand code the php coding, the xml files and etc.
    May 6, 2012 2:59 PM   in reply to Marit_SR
    The easiest CMS to convert Adobe Muse to is called "Concrete 5." It's a great CMS, created by some students from MIT.
