Hello everyone.
For some reason, FM keeps crashing when I try to apply a conditional text tag to a table (entire table). The funny thing is I have been doing this same thing for three months now with no problems before today, even have two tables in the same document with different tags applied to them and they are working fine. But when I try to add this one, I crash. I have rebooted my computer and made sure all my drivers are up to date, but now I'm at a loss. Any help?
Thanks.
Hi Newbie,
Which version of Framemaker you have?
Sometime what happens is the conditional text tag is corrupted and in that situations we delete and make a new conditional tag with the same formatting,however with a new name and than apply it.
If it still does not work,you can copy the complete document in a new document,keep both the document open,click on file-->import-->formats and copy all the formats from the old document to the new document and then apply the tag.
That should make it work.![]()
Harpreet.
Thank you for your replay Harpreet,
Unfortunately, it was a brand new tag, but I tried making it again and renaming it, still crashing. As far as importing the document, even if i kept the tags, wouldn't I lose what the tags were applied to? This document is one of many in a book for multiple products that are in the same family, and I don't want to lose all other model information for just one model.
NewbieTechWriter
EDIT:
I have FM 10, but not sure how to check which specific version. I was prompted to update when i first installed, but not since, so I guess I'm up to date, not reallys ure though.
My FM versions is:
10.0.2.419
Tried Importing, I get the tags, but not the text or pics associated with them.
What is MIF-washing? The name "Newbie" was chosen for a reason. I'm the first person in my compnay to use FM and I have been teaching myself from books and forums on the internet.
Also, tried calling the number, and it said it would be a $39 fee for help - I may ask my boss for permission to do that eventually, but not now.
NewbieTechWriter
Hi Newbie,
you need not to pay as if now.
Try the number again or just email me at tcssup@adobe.com and we will get back to you.
Harpreet.
What sort of crash is happening? Are you getting any specific error codes? If so, have you sent them in to fmerror@adobe.com<mailto:fmerror@adobe.com>? Is it happening on any document or just one particular one?
possibly - keep the troubled doc open, create a new blank doc and use the File > Import > Formats screen to bring over all formatting from the troubled doc into the new fresh one. Save the new doc and then do a Ctl-A in the old doc to select everything, Ctl-C to copy it and Ctl-V to paste it into the new fresh doc.
Ok used import format to get tags and copied and pasted into new document. Now the new document is doing it. But if I create a new document and just type in "lorem ipsum..." and apply tags, it works fine. Just tested if I can create and apply new tags in other documents in the same book, and it worked fine. It's just this one document, but apparently when import formatting or when I copy and paste the info I'm bringing over the problem into a new document.
Ok, this makes no sense. I just copied and pasted the text (did not import any tags or anything from the menu, just Ctrl+A then copy/paste), tried creating a tag and applying it to the table and it stopped responding. Can text actually become corrupt? I've never heard of that (grant you, I'm not a computer genius), but I don't know how else to explain it.
Yes, I can apply the tag to the pictures in the document, its only when applying to the table. I am selecting all rows in the table with the mouse and then selecting the tag, clicking the radio button "in" and then clicking the "Apply" button. It then asks "apply condition tag settings to all rows in table?" I hit "ok" and then it freezes, screen shots provided.
Pic 1: My project at table causing problems.
Pic 2: Me selecting the table and choosing to apply tag.
Pic 3: Me affirming I want to apply the condition to all rows.
Pic 4: Program stops responding.
Hmm, I see - what about doing it with a shortcut key? I keep my conditional pane minimized most of the time. I select the text/objects that I want conditioned, then press CTL-4 (control and four key together) - the status section of the screen (bottom left corner - where you get info about the paragraph and character tags being used) changes to display whatever condition the selection has applied to it. I can then either press the first letter of whatever condition tag I was to apply or click on the dropdown arrow to get a pop-up of the tag list.
Newbie,
I got your email and will get back to you on it,however meanwhile we can try this small step,may be it might work.
Make sure you have the backup of all your books somwhere on the computer.
Open the folder where Framemaker is installed in the Adobe folder in Program Files.
Make sure you close Framemaker before doing this.
There is a file that says "maker.ini",rename that file to "maker_old.ini".
Now launch Framemaker and open the book manually selecting the location its saved in the computer through Framemaker by clicking on the "open" icon.
Apply the tag now and take a look if it still crashes.
Could be a possibilty Framemaker might not lauch after renaming that file,if that happens,kindly rename it back to the original name "maker.ini".
Harpreet.
Thank you Error7103!
Selecting the anchor did work. I didn't know I could select the anchor (like I said, been teaching myself how to use FM, so some things that seem obvious to others I have yet to think of). I was able to select the anchor and apply the tag without it crashing.
-Newbie
EDIT: If I did something to cause this, let me know so that I don't do it again!
Glad to hear it.
I'm not sure I'd classify it as obvious. I only recently stumbled upon it myself. We use anchor tagging not just for tables, but also for anchored frames generally. This supports relatively painless variant manual editions.
By the way, I rarely put anchors at end-of-para. They can be hard to select, and the anchor sym tends to obscure punctuation (or its omission). So I put them elsewhere, usually right before a plural "s". Caution: anchors break the word for spell-check purposes, unless Adobe fixed this in FM7.2 or later.
If others cannot duplicate the crash on FM10, it might be something you're doing. But Frame is not free of anchored object problems. My user ID here reflects a common, if random, crash with right-run-in frames anchored to across-all-columns paras on FM7.1.
I just ran into this same problem myself in Frame 10. The document is a legacy installation guide I've been maintaining for 15 years. For some reason, conditionalization applied to a table row has caused Frame to crash whenever I try to do anything with conditionalization in that chapter only. For example, if I select "Show All" to try and reveal this particular row which is currently hidden, it will crash the application. Is this considered to be a known issue at this time? Does anyone know a workaround for it?
These same conditional tags have existed in this document for at least 5 years, so there's nothing new there. The table row itself was just added in this product release though. I took a copy of the chapter file from the release prior to this one, and I can use conditionalization normally there, but as soon as I try to recreate this new table row, and apply the appropriate conditional tag to it (and save it) the behavior returns.
I've tried completely stripping all conditionalization from the chapter, and recreating it...same thing happens.
Same thing is happening to me. We just upgraded to FM 10. I have had this book conditionalized in FM 9 without any issues for a logn time. Now, crashes all over the place. I did have to do a MIF wash but with so many of our sources conditionalized, this is really a pain to keep having this happen over and over again.
Jeff, I'm having a similar problem. I'm using Tech Comm Suite 4 with FrameMaker 11. I have a new HP laptop, and everything was working well until I tried to update a book. I received the message, "Cannot update this book, because it contains no openable or nongenerated files." All of my files were open in the book, and I have a TOC and APL file.
I tried saving all files to MIF, but when I tried to save back as FM, I got a message, "Filenames ending in .mif cannot be saved in Documetn format."
You mentioned a script for changing Book files to MIF in FM10. I don't see it in FM11. Where would I find it? I looked in File/Script/Run and Catalog.
I also opened a book that I had successfully updated using my old PC. I was able to update the files in that book.
I appreciate any adivce!
Best regards,
Karen Gross
Hi Karen,
You're kinda conflating several issues in here - you probably should have started your own thread...
Anyways, the book that's throwing the "un-updateable" message - is it from a prior version of FM? If so, open it and all the files it contains (use the Shift key to access the "All" commands), then save them all and close them all. Now that they've been saved in FM11 format, you can try again to open the book and update it. If you still get the message about no non-generated files, try renaming your ToC and generate a new one. If one is created, you can either import your formatting from the backed up one or delete the new and rename the old to match the new name; then try updating again.
When MIF washing, always pay attention to the "Files of Type" droplist to ensure you're opening or saving as the correct type. FM is lousy at remembering anything in this screen.
The BookMIFWash script has to be installed I think, check the TCS blog for details on that.
