CSXSInterface.instance.evalScript("alert('x', 'y', false)") Crashes IND When Debugging
Apr 10, 2012 1:22 AM
IND 5.0, Actionscript
Hi All,
I have found that the command CSXSInterface.instance.evalScript("alert('x', 'y', false)") works fine in a normal run (i.e., displays the Alert dialog in InDesign), but causes InDesign to crash and close if the same code is run in the debugger.
Any ideas?
TYIA,
mlavie
    Apr 15, 2012 2:59 PM   in reply to mlavie
    Do you get the crash with HostObject?
    Do you have a modal dialog open?
    Harbs
    Apr 16, 2012 12:44 AM   in reply to mlavie
    There's no reason to be using evalScript in InDesign.
    Try this method:
    http://cookbooks.adobe.com/post_Communicating_between_JavaScript_and_t he_Creative-17383.html
    Apr 18, 2012 1:23 PM   in reply to Harbs.
    Harbs, thank you very very very much for the link. It's very nice technique.
    But I have one question to you. Can I pass Array from jsx to sdk? I mean the real array, not a xml of string or anything?
    On the very bottom of the post in the link you provided, theres an example:
      var d:Document = new Document();
    d.hostObjectDelegate = jsxInterface.getDocumentFromJSX();
    And it works great, but only for SDK-specific classes, because they have a 'hostObjectDelegate" property/function.
    Array doesn't have one, so how can i get an array from JSX?
    Apr 18, 2012 1:22 AM   in reply to czlowiekuman
    Yes. You can pass an array, but it will not be an ActionScript Array type.
    Type it as an Object (which is basically all a javascript Array really is), and it'll work as expected.
    Something like this:
    Javascript:
    function getArray(){
        return [1,2,3,4];
    ActionScript:
    var jsArray:Object = jsxInterface.getArray();
    trace(jsArray[1]); // returns "2".
    Harbs
    Apr 18, 2012 1:13 PM   in reply to Harbs.
    I've seen several references to the jsxInterface, but my compiler can't seem to find it.  I'm using CS Extension Builder 4.6.  What library/imports do I need to get access to this object??
    Apr 18, 2012 1:21 PM   in reply to Meate
    Its shorthand for referencing HostObject.
    Read the cookbook post. It's all explained there.
    Harbs
    Apr 18, 2012 1:35 PM   in reply to Harbs.
    I'm an idiot.  Let's just leave it at that
    Apr 18, 2012 2:45 PM   in reply to Harbs.
    Thank you very much Hrabs. With this 2 short post you helped me more, than anything and anybody since my start with creative SDK (like 2 months now)
