Possible Bug Report: Screen Artifacts when manipulating large documents
Apr 18, 2012 1:33 PM
Tags: #photoshop #osx #bug #cs6 #graphics_card #bug_report #photoshop_cs6 #cs6_beta #photoshop_cs6_beta
I suspect this problem is unique to underpowered displayport Macs but when manipulating large documents (>70MB) with many layers (>300) screen artifacts will often appear as pictured below.
Steps to reproduce:
  1. Get yourself a large, complicated doc and a Mac laptop with only 256 MB VRAM plugged into a 27" cinema display using displayport plug
  2. Work on it for a while (change text, move layers, add shadow effects, almost anything, really)
  3. Observe full-screen artifacts appear occasionally which "stick" to the screen until you perform another operation/edit, at which point they temporarily disappear
I have literally tried all of the different GPU settings in the Preferences and none change the observed problem.
I have a MacBookPro 6,2 and have "automatic graphics switching" off so that it only uses the NVIDIA GeForce GT 330M card and NOT the built in Intel HD Graphics
The only other place I have observed this outside of PhotoShop is when I'm running my screen saver, which is what makes me suspect that it's more of an Apple problem than an Adobe one. That said, thought I'd post it here just in case it is something that can be minimized (or eliminated) with some code.
Adobe Photoshop Version: 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00) x64
Operating System: Mac OS 10.7.3
System architecture: Intel CPU Family:6, Model:37, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Physical processor count: 2
Logical processor count: 4
Processor speed: 2400 MHz
Built-in memory: 8192 MB
Free memory: 0 MB
Memory available to Photoshop: 6818 MB
Memory used by Photoshop: 70 %
Image tile size: 1024K
Image cache levels: 4
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Normal
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Version: 2.1 NVIDIA-7.18.11
OpenCL Unavailable
Video Card Vendor: NVIDIA Corporation
Video Card Renderer: NVIDIA GeForce GT 330M OpenGL Engine
Display: 2
Display Depth:= 32
Display Bounds:=  top: 390, left: -1680, bottom: 1440, right: 0
Video Renderer ID: 16918034
Video Card Memory: 204 MB
Video Rect Texture Size: 8192
OpenCL Unavailable
Display: 1
Main Display
Display Depth:= 32
Display Bounds:=  top: 0, left: 0, bottom: 1440, right: 2560
Serial number: Tryout Version
Application folder: SledgeHammer:Applications:Adobe Photoshop CS6:
Photoshop scratch has async I/O enabled
Scratch volume(s):
  SledgeHammer, 446.8G, 156.1G free
Required Plug-ins folder: SledgeHammer:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
Primary Plug-ins folder: SledgeHammer:Applications:Adobe Photoshop CS6:Plug-ins:
Additional Plug-ins folder: not set
Installed components:
   adbeape.framework   adbeape   3.3.8.19346   66.1025012
   AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
   adobe_caps.framework   adobe_caps   5.0.11.0   1.256674
   AdobeACE.framework   AdobeACE   2.19.18.19243   66.492997
   AdobeAGM.framework   AdobeAGM   4.26.17.19243   66.492997
   AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
   AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
   AdobeBIB.framework   AdobeBIB   1.2.02.19243   66.492997
   AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.492997
   AdobeCoolType.framework   AdobeCoolType   5.10.31.19243   66.492997
   AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120201
   AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
   AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
   AdobeLinguistic.framework      17206
   AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
   AdobeOwl.framework   AdobeOwl   4.0.93   66.496052
   AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
   AdobePDFSettings.framework   AdobePDFSettings   1.4
   AdobePIP.framework   AdobePIP   6.0.0.1642
   AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
   AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
   AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
   AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
   AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
   ahclient.framework   ahclient   1.7.0.56
   aif_core.framework   AdobeAIF   3.0.00   62.490293
   aif_ocl.framework   AdobeAIF   3.0.00   62.490293
   aif_ogl.framework   AdobeAIF   3.0.00   62.490293
   AlignmentLib.framework   xcode   1.0.0.1
   amtlib.framework   amtlib   6.0.0.75
   boost_date_time.framework   boost_date_time   6.0.0.0
   boost_signals.framework   boost_signals   6.0.0.0
   boost_system.framework   boost_system   6.0.0.0
   boost_threads.framework   boost_threads   6.0.0.0
   Cg.framework   NVIDIA Cg
   CIT.framework   CIT   2.0.5.19287   145486
   data_flow.framework   AdobeAIF   3.0.00   62.490293
   dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
   dvacore.framework   dvacore   6.0.0.0
   dvamarshal.framework   dvamarshal   6.0.0.0
   dvamediatypes.framework   dvamediatypes   6.0.0.0
   dvaplayer.framework   dvaplayer   6.0.0.0
   dvatransport.framework   dvatransport   6.0.0.0
   dvaunittesting.framework   dvaunittesting   6.0.0.0
   dynamiclink.framework   dynamiclink   6.0.0.0
   FileInfo.framework   FileInfo   66.145433   66.145433
   filter_graph.framework   AdobeAIF   3.0.00   62.490293
   hydra_filters.framework   AdobeAIF   3.0.00   62.490293
   ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
   ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
   image_compiler.framework   AdobeAIF   3.0.00   62.490293
   image_flow.framework   AdobeAIF   3.0.00   62.490293
   image_runtime.framework   AdobeAIF   3.0.00   62.490293
   LogSession.framework   LogSession   2.1.2.1640
   mediacoreif.framework   mediacoreif   6.0.0.0
   PlugPlug.framework   PlugPlug   3.0.0.383
   UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
   wrservices.framework
Required plug-ins:
   3D Studio 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
   Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
   ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc.  All rights reserved. - from the file “AdobeADM.bundle”
   Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Average 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
   Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Camera Raw 7.0 (308), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
   Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Cineon 13.0 20120305.m.415 2012/03/05:21:00:00  ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
   Clouds 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
   Collada DAE 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
   Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Crop and Straighten Photos 13.0 20120305.m.415 2012/03/05:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
   Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
   Difference Clouds 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
   Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Eazel Acquire 13.0 20120305.m.415 2012/03/05:21:00:00  ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
   Embed Watermark NO VERSION - from the file “DigiSign.plugin”
   Enable Async I/O 13.0 20120305.m.415 2012/03/05:21:00:00  © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
   Entropy 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   FastCore Routines 13.0 20120305.m.415 2012/03/05:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
   Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Flash 3D 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
   Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Google Earth 4 KMZ 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
   Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
   IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   JPEG 2000 13.0 20120305.m.415 2012/03/05:21:00:00  ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
   Kurtosis 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
   Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
   Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
   Matlab Operation 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
   Maximum 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Mean 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Measurement Core 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
   Median 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Minimum 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   MMXCore Routines 13.0 20120305.m.415 2012/03/05:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
   Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Multiprocessor Support 13.0 20120305.m.415 2012/03/05:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
   Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   NTSC Colors 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
   Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
   OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   PCX 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
   Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Photoshop 3D Engine 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
   Picture Package Filter 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
   Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Pixar 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
   Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Portable Bit Map 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
   Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Radiance 13.0 20120305.m.415 2012/03/05:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
   Range 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Read Watermark NO VERSION - from the file “DigiRead.plugin”
   Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
   ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
   Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Skewness 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Solarize 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
   Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Standard Deviation 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Summation 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   U3D 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
   Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
   Variance 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Wavefront|OBJ 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
   Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Wireless Bitmap 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
   ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Plug-ins that failed to load: NONE
Flash:
   Mini Bridge
   Kuler
Installed TWAIN devices: NONE
    Apr 18, 2012 1:58 PM   in reply to aaronrdeutsch
    Yeah, that's a GPU driver bug or bad VRAM.
    Apr 18, 2012 2:17 PM   in reply to Chris Cox
    I'd suggest updating the driver, but it looks like it's not longer being updated for your model of card, it seems that this card hasn't had it's drivers updated for Lion.
    Apr 18, 2012 5:15 PM   in reply to Chris Cox
    Chris I've seen something similar - the first time I've ever seen something like that in Photoshop on this machine - see attached. Any scaling (free transform) I did on a layer created persistent pixel artifacts like the ones you see here. The PC was a bit RAM starved at the time, so that may be a part of the explanation, but it certainly startled me (and as I said this was persistent, burned in pixel artifacts inside Photoshop CS6). Bugged in the prerelease, but seems to have gone unnoticed.
    Apr 18, 2012 9:03 PM   in reply to aaronrdeutsch
    It also appears you have no free memory available for use.
    Pattie
    Free memory: 0 MB
    Apr 19, 2012 10:54 AM   in reply to Mathias Vejerslev
    Mathias
    Typically these artifactings are all related to the video driver -- that's the best place to look to resolve such artifacts
    If you want our help, you can include your system info here on the forums as a starting point to see where to look for resolution!
