tatchou30
Installation adobe première CS5 échoue
Apr 18, 2012 3:06 PM
Bonjour, j'ai un problème quand je tente d'installer la version d'évaluation de Adobe Première CS5 j'ai ce message d'érreur:
"Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 57 error(s), 53 warning(s)
----------- Payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0 -----------
ERROR: Error 1327.Invalid Drive: X:\
ERROR: Install MSI payload failed with error: 1603 - Erreur irrécupérable lors de l'installation.
MSI Error message: Error 1327.Invalid Drive: X:\
WARNING: DW036: Payload cannot be installed due to dependent operation failure
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe ExtendScript Toolkit CS5.5: Install failed
ERROR: DW050: - Microsoft_VC90_ATL_x86: Install failed
ERROR: DW050: - Microsoft_VC90_CRT_x86: Install failed
ERROR: DW050: - Recommended Common Fonts Installation x64: Install failed
ERROR: DW050: - AdobePDFL x64 CS5: Install failed
ERROR: DW050: - DynamiclinkSupport: Install failed
ERROR: DW050: - Microsoft_VC80_MFCLOC_x86_x64: Install failed
ERROR: DW050: - Adobe After Effects CS5.5 Support: Install failed
ERROR: DW050: - Adobe XMP Panels CS5: Install failed
ERROR: DW050: - Pixel Bender Toolkit: Install failed
ERROR: DW050: - Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64: Install failed
ERROR: DW050: - Photoshop Camera Raw: Install failed
ERROR: DW050: - Camera Profiles Installer: Install failed
ERROR: DW050: - Adobe Extension Manager CS5.5: Install failed
ERROR: DW050: - Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll: Install failed
ERROR: DW050: - AdobeColorCommonSetRGB: Install failed
ERROR: DW050: - Microsoft_VC80_CRT_x86_x64: Install failed
ERROR: DW050: - Adobe Device Central CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - AdobeMotionPicture CS5.5: Install failed
ERROR: DW050: - Photoshop Camera Raw (64 bit): Install failed
ERROR: DW050: - Microsoft_VC90_MFC_x86: Install failed
ERROR: DW050: - Adobe Media Encoder CS5.5 X64: Install failed
ERROR: DW050: - AdobeTypeSupport CS5: Install failed
ERROR: DW050: - Adobe CSXS Infrastructure CS5.5: Install failed
ERROR: DW050: - Adobe After Effects CS5.5_AdobeAfterEffects10.5fr_FRLanguagePack: Install failed
ERROR: DW050: - AdobeHelp: Install failed
ERROR: DW050: - Required Common Fonts Installation x64: Install failed
ERROR: DW050: - Microsoft_VC90_ATL_x86_x64: Install failed
ERROR: DW050: - Adobe Story: Install failed
ERROR: DW050: - Microsoft_VC90_CRT_x86_x64: Install failed
ERROR: DW050: - Microsoft_VC80_CRT_x86: Install failed
ERROR: DW050: - Adobe Device Central CS5.5_DeviceCentral3.5LP-fr_FR: Install failed
ERROR: DW050: - AdobeCMaps x64 CS5: Install failed
ERROR: DW050: - AdobeTypeSupport x64 CS5: Install failed
ERROR: DW050: - Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All: Install failed
ERROR: DW050: - Adobe After Effects CS5.5 Third Party Content Wrapper: Install failed
ERROR: DW050: - Microsoft_VC90_MFC_x86_x64: Install failed
ERROR: DW050: - AdobeOutputModule: Install failed
ERROR: DW050: - Microsoft_VC90_MFCLOC_x86: Install failed
ERROR: DW050: - AdobePDFL CS5: Install failed
ERROR: DW050: - AdobeCMaps CS5: Install failed
ERROR: DW050: - Adobe After Effects CS5.5 Presets: Install failed
ERROR: DW050: - Microsoft_VC80_MFC_x86_x64: Install failed
ERROR: DW050: - Adobe After Effects CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - AdobeColorVideoProfilesAE CS5.5: Install failed
ERROR: DW050: - Adobe Player for Embedding x64 3.1: Install failed
ERROR: DW050: - Adobe SwitchBoard 2.0: Install failed
ERROR: DW050: - Microsoft_VC80_MFC_x86: Install failed
ERROR: DW050: - Adobe Player for Embedding 3.1: Install failed
ERROR: DW050: - Microsoft_VC80_MFCLOC_x86: Install failed
ERROR: DW050: - AdobeJRE: Install failed
ERROR: DW050: - Suite Shared Configuration CS5.5: Install failed
ERROR: DW050: - Adobe Bridge CS5.1: Install failed
ERROR: DW050: - Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All: Install failed
Impossible de l'installer j'ai voulu chercher sur le site d'abobe ou ils expliquent comment résoudre le problème mais je ne comprends pas car c'est anglais et surtout ça à l'air compliqué et pas clair est-ce que quelqu'un à déjà eu ce problème ou connait la solution ? C'est vraiment très important car j'en ai besoin pour monter des films amateurs et ça fait 3 jours que je m'arrache les cheveux...
Merci d'avance
EDIT: je suis sous windows 7 64 bits
  • Pierre Courtejoie
    Jan 11, 2006
    Apr 18, 2012 3:16 PM   in reply to tatchou30
    Bonjour, essayez vous d'installer ailleurs que dans le program files du C: ? Les permissions sont-elles normales?
    Avez-vous essayé d'installer en tant qu'administrateur?
  • Pierre Courtejoie
    Jan 11, 2006
    Apr 22, 2012 2:47 AM   in reply to tatchou30
    Bonjour, pouvez-vous me décrire comment vous faites pour installer?
    Vous devez extraire le contenu du fichier zip avant de cliquer sur install.exe
    Sep 23, 2012 6:31 AM   in reply to Pierre Courtejoie
    J'ai le même problème que Tatchou30, j'essaie toute les solutions proposée et rien ne fonctionne..
    Exit error 7 est toujours la problème d'installation quelque soit la méthode que j'utilise pour installer
  • Pierre Courtejoie
    Jan 11, 2006
    Sep 26, 2012 11:20 AM   in reply to tatchou30
    Les 3 en même temps? Installer sur le C:, à l'endroit par défaut, en tant qu'administrateur, en vérifiant que les permissions sont OK?
    Utiliser le creative suite cleaner tool avant de réessayer: http://www.adobe.com/support/contact/cscleanertool.html
