mnmazza
Can't Install. An error occurred while installing Adobe AIR
Apr 13, 2012 8:09 AM
Tags: #adobe_air #install_problem
I can't install Adobe AIR. I'm getting the infamous error:
"An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator."
  • I'm the administrator of the computer.
  • I'm running Windows 7 Ultimate 32-bit.
  • I've tried the right-click-run-as-administrator solution and I'm getting the same error.
  • I've read Troubleshoot AIR installation | Windows and none of the solutions worked.
  • I'm installing the latest AIR version (I've tried older versions too)
  • I've tried Microsoft Install and Uninstall Fix It and AIR doesn't appear on the list of programs.
Here is my install log:
[2012-04-13:11:31:20] Runtime Installer begin with version 3.2.0.2070 on Windows 7 x86
[2012-04-13:11:31:20] Commandline is:
[2012-04-13:11:31:20] No installed runtime detected
[2012-04-13:11:31:42] Relaunching with elevation
[2012-04-13:11:31:42] Launching subprocess with commandline c:\users\mmazza\appdata\local\temp\aira62d.tmp\adobe air installer.exe -ei
[2012-04-13:11:31:42] Runtime Installer begin with version 3.2.0.2070 on Windows 7 x86
[2012-04-13:11:31:42] Commandline is: -stdio \\.\pipe\AIR_5604_0 -ei
[2012-04-13:11:31:42] No installed runtime detected
[2012-04-13:11:31:43] Starting silent runtime install. Installing runtime version 3.2.0.2070
[2012-04-13:11:31:43] Installing msi at c:\users\mmazza\appdata\local\temp\aira62d.tmp\setup.msi with guid {47FA2C44-D148-4DBC-AF60-B91934AA4842}
[2012-04-13:11:31:45] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-04-13:11:31:45] Rolling back install of c:\users\mmazza\appdata\local\temp\aira62d.tmp\setup.msi
[2012-04-13:11:31:45] Rollback complete
[2012-04-13:11:31:45] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-04-13:11:31:45] Runtime Installer end with exit code 7
[2012-04-13:11:31:47] Runtime Installer end with exit code 7
Hope someone can help. Thanks.
  • Chris Campbell
    May 4, 2010
    Apr 13, 2012 5:02 PM   in reply to mnmazza
    Unfortunately, the error is in the MSI portion of the installer.  This requires another log file to see what's going on.  Usually the Microsoft fix it takes care of this for us, but as you mentioned if AIR isn't in the list it's not very helpful.  Hopefully viewing the log will show us what's wrong and we can fix it.
    http://support.microsoft.com/kb/223300
  • Chris Campbell
    May 4, 2010
    Apr 17, 2012 8:56 PM   in reply to mnmazza
    Can you right click on the key and select permissions?  If so, make sure you give your user account full permissions and try deleting again.
    Chris
  • Chris Campbell
    May 4, 2010
    Apr 18, 2012 4:10 PM   in reply to mnmazza
    Does it make any difference if you try to run regedit (regDALC or RegDelNull) by right clicking and selecting "run as administrator"?
  • Chris Campbell
    May 4, 2010
    Apr 26, 2012 4:02 PM   in reply to mnmazza
    Have you tried any registry repair utilities?  I unfortunately don't have any recent experience with these so I don't have anything I can recommend.  You might also want to post on a Microsoft board to see if they know how you might be able to repair your registry.
    Oct 8, 2013 3:53 AM   in reply to mnmazza
    Kept having the same issues with the program until i checked the following things
    1. Go to Controll panel , see administrative services, then click Services
    2. Make sure the windows Installer service is Set to : Auto, and Enabled
    3. Extract the Adobe AIR Setup with an Archiver , I.e 7zip should be fine \
    4. Run setup after the extraction process.
    5. Be sure you run 32Bit version for 32bit machine  and 64Bit accordingly.
    Nov 25, 2013 12:50 PM   in reply to armdev
    Hi Armdev - I tried this using the setup.msi file but get an error message that says;
    could not access network location (computed)
    Again if I try to use the installer.exe pack I get the same old need admin permission message.
    I also tried disabling the firewall and antivirus but no joy.
    I'm on xp pro version 2002 sp3
    ...any suggestions?
    Thanks for your help.
