bsaucedo1
Hi, the Photoshop Element download that I get for my new IMac is getting a "invalid checksum" error?
Dec 12, 2011 1:49 PM
I don't think this is a problem on my side...any ideas?
    Dec 12, 2011 2:22 PM   in reply to bsaucedo1
    Hi bsaucedo1,
    It's my understanding that an "invalid checksum" error is a suggests that the file that you are trying to access is corrupt/damaged in transit to your computers disk. This could be because of an issue with network connection (yours or ours), or possibly damaged hardware. There's a disscusion on Apple's forums about troubleshooting this issue that might help you solve your problem:
    https://discussions.apple.com/thread/1736023?start=0&tstart=0
    Sorry I can't give you a more sure answer, I'll make sure to pass this on to one of our more experienced employees to try and help you out.
    Tyler,
    Calculating status...
    Apr 18, 2012 11:32 PM   in reply to tgough88
    Hold on. the fix you're suggesting is from 2008! how does this have any bearing on an issue in 2011-2012? i've tried to download and install a trial of photosp elements for 8 hours!!! i have a 100mb internet connection so download only takes a few minutes, but i've done it 6 times now and without success. everytime i get an invalid checksum error. i've tried downloading from US, UK and Germany and always the same error - VERY frustrating. i've read the blogs and none of the suggestions work - even downloading on one mac and transferring the file to another for install.
    any up to date advice?
    Apr 18, 2012 11:42 PM   in reply to elem201204
    Go to Finder > Type Disk Utility > Preferences and simply unchecking the box that says "Verify Checksums" . Close Disk Utility. Then PSE dmg should open fine and the program should install without any issues.
    (You might want to re-check the verify checksums box after you've finished the installation though because it's there to help prevent the installation of corrupted .dmgs that could potentially harm your computer)
    Apr 19, 2012 2:58 AM   in reply to Manish Kumar
    So I did what you said and the installation got part way through before encountering errors...
    i have 750mb of space so no issue there. any other ideas? As I said, 6 times I've downloaded the file and the same error every time and I got rid of cookies etc that was suggested in another blog
    Apr 19, 2012 7:02 AM   in reply to Manish Kumar
    Hi Manish,
    this didn't fix the problem as when I ran the install it failed so it does
    look like the 6 times I downloaded software there is a checksum problem...
    Apr 19, 2012 7:03 AM   in reply to elem201204
    From are you downloading the software....?
    Apr 19, 2012 7:34 AM   in reply to Manish-Sharma
    I tried, UK, US and Germany. Really frustrating and am on the brink of
    buying Pixelmator as I need to do some work today...
    Apr 19, 2012 7:45 AM   in reply to elem201204
    download from here :-
    http://prodesigntools.com/photoshop-elements-10-direct-download-links- pse-premiere-pre.html
    and then .....It will be faster then before it is direct download link without the download manager
    Apr 19, 2012 12:52 PM   in reply to Manish-Sharma
    Thanks, I'll try
    Sent from my iPad
    Apr 21, 2012 5:27 AM   in reply to bsaucedo1
    I am having the exact same problem.  I also accidentally downloaded Elements Premier (after the first Elements had a checksum error) and it installed just fine.   I downloaded Elements again and it had the same checksum error.  I'm now trying the direct download site suggested.  I hope it works.  No need to buy this product if I can't install it in the first place - and I really want to buy it.
    Apr 21, 2012 8:01 AM   in reply to cvillegal
    The direct download worked!  Thanks!
