phneville
How to create log files and save them on a local folder?
Apr 18, 2012 8:04 PM
Tags: #configuration #log #logger
How can I create multiple log files and save them on a local folder?
I need to create one file for each level(ERROR, INFO, etc.). How do I configure the logger to do this? Thanks.
    Apr 18, 2012 10:26 PM   in reply to phneville
    Hi phneville,
    Please follow these steps:
    1. In CRXDE, create a new folder named "config" inside /apps/<%YOUR_APP%>.
    2. Inside config, create a new node with:
              Type : sling:OsgiConfig (select from drop down)
    3. Click Finish to save changes.
    4. In CRXDE, select the node apps/<%YOUR_APP%>/config/ org.apache.sling.commons.log.LogManager.factory.config-demo and add the following properties.
    Property Name        Type                                                 Value
    org.apache.sling.commons.log.file                                          String                                          ../logs/demo.log
    org.apache.sling.commons.log.level                                        String                                          Debug
    org.apache.sling.commons.log.names                                    String                                          apps.<%YOUR_APP%>
    org.apache.sling.commons.log.pattern                                   String                                           {0,date,dd.MM.yyyy HH:mm:ss.SSS} *{4}* [{2}] {3} {5}
    5. Add the log commands to the component file
         Eg: log.debug(“inside filename.jsp”);
    6. Run the component.
    7. Navigate to "<%cq-install-directory%>/crx-quickstart/logs‟.
    8. Open the demo.log file to see the log statements
    And you should be good to go...
    Apr 19, 2012 1:46 AM   in reply to phneville
    In step 4, you have specified "org.apache.sling.commons.log.level" as debug.
    Similarly create new nodes for various logging levels.
