Hi
I am on CS 5.5. I have 30 or so clips in the timeline. I want to change the default length of a transition and then add f.ex a cross dissolve to all clips and then an audio transition too.
Can I change the setting for def. dur. And then maybe lasso the clips before adding the transition?
Ulf
You may specify a transition as a default one, select clips in the timeline and choose Sequence -> Apply Default Transitions To Selection.
Ulf,
Fuzzy beat me to the punch.
One admonition - if you do change the default Transitions' Duration, do not forget that you did so. Same if you reset the Default Transition, as you might butt up against that choice down the line. Both have "bitten" me in the past. Luckily, it's only a "head-scratcher" for a moment, until my memory kicks back in.
Good luck,
Hunt
