Hi everyone, I am experiencing the same exact bug.
Pasting from the clipboard stops working after a certain time. I am also running Windows 7 64bit, Photoshop 64bit, and have 8 GIGs of ram installed. My pasting from the clipboard stops working after a few hours of designing. Pasting in from illustrator, screen caps etc. Obvisouly this issue is with photoshop and or memory. When the pasting from the clipboard stops working I can't even paste in text into photoshop! Even if I clear the clipboard and all history within photoshop.
Ironically, whatever I have I can still paste in Illustrator CS5. So how could it be a windows clipboard issue? Wondering if this is an obscure bug or what?
Many thanks to all the posts above. I tried all of them. Photoshop CS5 32 bit does not have the problem. I never noticed that because I always use 64 bit.
The only solution that restored the paste function was to completely remove the NIK presets folder from the "Adobe Photoshop CS5 (64 Bit)/Plug-ins" folder.
NIK has a problem with their 64 bit support!
Hope this helps.
Guy
This whole clipboard issue is a huge CF. I don't use any plugins and have the same problems. I have resolved myself to the fact that Adobe will probably never fix it. Mostly because they want to point the blame somewhere else - even though that every app on my system works with the clipboard perfectly and consistently.
::face palm::
I tried all the solutions in this thread. The only one that works consistently is removing the NIK plugins entirely. I bundled all the NIK plugins in the plugin subdirectory into one subdirectory named "NIK". When I need to use the clipboard I simply move the "NIK" directory out of the photoshop plugin directory. I moved all the non photoshop plug ins including "NIK" into the auxiliary plugin directory.
I haven't gone so far as to try to identify which of the NIK modules have the problem. I'll probably leave that up to the NIK folk.
Guy
Yes, I downloaded and installed all the latest updates. NIK claims it isn't their problem. I have a lot of plugins:
Digimarc
EPP_Pro
FocalPoint 2.0.plugin
FocusMagic.plugin
OnOne
Panels
Photomatix
Topaz
NIK isn't in right now because I need to use the clipboard.
I don't want to go back and undo all the registry fixes I made but that might show some interaction with the clipboard. Right now I am happy I have a solution that works consistently and is repeatable.
Guy
No, more like that's a clue hat there is a bug. The rest is circumstantial. Seems to me, anyway. However, the impetus lies with Nik, as they want their software to operate as a plug-in to Photoshop. The clash my very well be unavoidable.
Correct me if I am in error, but Nik's software will function without Photoshop, so it may be a case of unfortunate circumstances.
I would hate to be a judge having to decide who's at fault. Sounds like a messy divorce case. Maybe the two should never have gotten together in the first place! ![]()
Maybe we need to get past the idea of a "bug". Just where is that critter and where did it take up residence?
At first I thought the problem was with how Adobe wrote the plug-in interface specification. That's why I consolidated each vendor's plug-ins in their own sub directory. That made it easier to move the plug-ins in and out of the Photoshop plug-in directory.
I was surprised after the 3+ years of posts on this problem that NIK was the only one that consistently creates the problem. So NIK does have a problem with one or more of their plug-ins.
That is not to say there isn't some interaction with one or more of the registry fixes outlined in these posts. I applied them all. It could be that one or more of the registry patches fixed problems with other vendors. In that case then Adobe shares part of the problem.
Now that I have a solution that works, I have no further incentive to help trouble shoot vendor problems.
Guy
In a certain sense, this actually could be considered part of the root cause...
What I mean by that is that Photoshop allows plug-ins to run in its address space. Basically, at its core a plug-in is just a subprogram that Photoshop calls. This is powerful. But with great power comes great responsibility not to screw up the parent environment!
I think a lot of problems come from the observation that plug-in writers always seem to want to do more than they're allowed to do within the plug-in SDK, by tinkering with that host environment... Things like put their own menus up, open new panels, and a whole host of other things they think will differentiate their product from the crowd.
-Noel
Nik isn't exactly a newcomer, so you might think they would get the facts straight.
It's interesting that, of all the alternate photo editing software out there, DxO might want to be a plug-in but they studiously avoid that, thankfully. But even there, DxO open and Bridge open, if you drag from Bridge to DxO, Bridge goes down.
It's also interesting that reindeer graphics has plug-ins for PS, but they show up under a different Menu than the others do. They have never been a problem.
Where do they show up, exactly?
Different types of plug-ins do go in different places... For example, Automation plug-ins go in the File - Automate menu. Filter plug-ins - the ones we most often think of - of course go in the FIlter menu. Submenus are sanctioned.
-Noel
The Reindeer Graphics plug-in, Select Edges, opens under Select. I don't know about the others.
Just looked at their website, which is incomplete at the moment. Of interest is, under Optiplex, a function called refocus, which they say is not the same as sharpening. They both use deconvolution. I believe they were the folks that led me to Richardson-Lucy. The only images where I could actually use it were my Tech Pan images, which are on a micrograin stock. The results, back around the turn of the millennia, if not earlier, showed gonzo sharpening!
Hmmmm.....refocus. I could use that! ![]()
I could not get anywhere else as the site is incomplete.
I have to re-investigate their products.
Jeanie, have you read through this thread? There are some plug-ins identified herein that interfere with Photoshop.
If you don't believe you have the problem cause(s) listed above in this thread (e.g., Nik plug-ins, etc.), perhaps it would be a good idea if you would describe exactly what you're doing, down to the mouse movement and keystroke. There's always the possibility that you expect something to work one way when actually it works another way.
-Noel
It seems that this question is yet unanswered... I have/had the same problem in Photoshop 64 bit on Windows 7, and even though the issue is still there, I'd like to share a weird workaround that works for me. I simply hold down PrntScr (print screen) and then press Alt. Note, you mustn't release PrntScr until you see the "hourglass"-symbol popping up. You usually use the Alt-button when you want to do a printscreen of a portion of the screen, but that won't work if you for instance are inside Photoshop, for exampel creating a tutorial, and want the selected menu to be printscreened as well. But, if you do it the other way around, PrntScr+Alt, it somehow clears the print screen cache. This works every time for me, hopefully it can help someone else!
/Helena
Registered just to give my 2 cents.
Landed here in search for a solution for this problem and it seemed to be plugin-caused. I started to uninstalling what I have..
It ended up being the xNormal and its PS plugin. After uninstalled, my clipboard issues were gone. So if anyone who reads this has xNormal installed, it's worth a shot to uninstall it and see if it solved.
I have a screen shot program that interferes with the key combination you recommend. However, when I unload that program from memory and press the your key combination, I get a screen shot of the whole screen. But then, if I copy anything else to the clipboard, PhotoShop behaves as it should. So your method works for me if I disable my own screen print program and if I take a screen shot first of the whole screen. Then...perfect.
Thanks for this idea.
-wick
Hi, Just trying to add a little more of my findings with this problem 2 days ago I upgraded my pc to an AMD phenom X3, 4GB RAM, new install of Windows 7 64bit and Photoshop CS5 32/64 bit default plugins etc.. I updated drivers etc... yet I have the copy/paste problem I tried all workarounds and patches and no avail I even tried installing CS6 and still same problem..
Buuut!
I noticed I only have this problem when I open existing PSD I have in my drive, which I created in my previouse machine with PS CS5 in Windows XP.
What I want to do is open an existing psd so as to copy a clip and later paste into another project but I can´t the copy/paste options in edit are grayed out.
I can drag and drop into another project within PS on a new tab but copy/paste are disabled. However on a new project in another TAB copy and paste works fine as long as I don´t use any clip previously created in XP!!!!!
Well hopefully I shed some bit of info for someone and I will wait and see if a solution is found...
