<body>
<div id="holder">Content for id "holder" Goes Here</div>
<div id="apDiv1"></div>
</body>
I want the holder to be in front of the ap div but when I put the ap div on -1 z-index the ap div works fine in Explorer but not Firefox.
APDivs are removed from normal document flow. As such they are disconnected from everything else around them.
Frankly, I don't understand what you mean by "I want the holder to be in front of the ap div." Backwards/forwards, left side/right side, top/botom??
As John said, for best answers to layouts questions, please show us a link to your test page. Briefly describe what you want to achieve.
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
@ Nancy
I hope you do not mind me using one of your phrases
The proper procedure is DO NOT USE APDIVS for primary layouts.
@ OP
You can achieve a better result using statically positioned div's (default value) and applying widths, floats and margins. Although regarded by some as being a hack, there is nothing wrong with using negative margins to show one div over and above another div.
Gramps
http://www.frankton-lapel.org/schools/lshs/baylor_jake_stfo/Baylor_jak e_index.html
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
<link href="css/baylor_jake.css" rel="stylesheet" type="text/css" />
<style type="text/css">
body {
background-color: #f2f0d5;
#apDiv1 {
width:100%;
height:241px;
left: 0px;
top: 164px;
background-color: #999900;
position: absolute;
z-index: -1;
#apDiv2 {
width:1000px;
height:960px;
z-index:1;
background-color: #30F;
left: 137px;
top: 11px;
margin-right: auto;
margin-left: auto;
</style>
</head>
<body>
<div id="apDiv2"></div>
</body>
</html>
The green box in the background shows up the way I want it to but in Firefox the Green Box dissapears. The green box is an ap div with a -1 zindex and the main holder div would be ap Div2 but it is not actually an ap div.
If there is an easier layout would you please tell me how. Thanks.
Some people will invariably be using "out of date browsers." So the bigger question here is why complicate your layout with APDivs when you don't need to? A simple repeating background image on the body selector will do what you want.
Live Example (view source in browser to see the code):
http://alt-web.com/TEST/background-test.html
Nancy O.
http://www.frankton-lapel.org/schools/lshs/caulin_stfo/ndex.html
Here is the page we are currently working on. We have two different sized monitors and the background (ap div) is aligned on one monitor but not aligned on the other. Any thoughts?
margin:0 auto is a shorter way of expressing the following CSS rules. The value of auto is browser default.
margin-top:0;
margin-right: auto;
margin-bottom:0;
margin-left: auto;
When combined with width, a margin-right & margin-left of 'auto' centers the container in browsers.
In web design, it's best to avoid using explicit height values on containers because this limits how much content the container can hold. Unlike height, min-height does not limit the containers capacity to hold more content when needed.
CSS margins
http://www.w3schools.com/css/css_margin.asp
CSS min-height
http://www.w3schools.com/cssref/pr_dim_min-height.asp
CSS height
http://www.w3schools.com/cssref/pr_dim_height.asp
CSS Box Model
http://www.w3schools.com/css/css_boxmodel.asp
CSS Backgrounds
http://www.w3schools.com/cssref/css3_pr_background.asp
Nancy O.
If you look here
you can see that the gold background doesn't line up with the spry bar and the bottom of the div.
http://www.msn.com/ If you look on msn you can see the blue menu bar goes from the left of the screen all the way to the right with no space issues. We are wanting basicaly the same idea just to a bigger scale. How would you do this?
Not how I would do it because I don't believe you should be using APDivs for any of this.
However, based on what you have so far, change your #apDiv1 styles as follows:
#apDiv1 {
position:absolute;
width:100%;
min-height:500px;
z-index:-1;
left: 0px;
top: 120px; /**adjust as needed**/
background-color: #CABA66;
Nancy O.
How would you do it without using ap divs?
With default CSS positioning, margins, floats, classes, background-colors and borders.
To illustrate, Copy & Paste the following code into a new, blank HTML document. Preview in browsers with increased/decreased text sizes. You can't break this layout because it's cohesive. Your APDiv layout falls apart when text size is increased in browsers.
<head>
<title>Example CSS Layout, no APDivs</title>
/**add browser scroll to short pages**/
html {overflow-y:scroll; font-size:65.25%;}
body {
margin:0;
padding:0;
font-size: 1em;
font-family:"Lucida Sans Unicode", "Lucida Grande", sans-serif;
background-color:#FFFFCC;
color:#4F5972
#header {
margin:0;
padding:0;
min-height: 100px;
#nav {
margin:0;
padding:0;
min-height: 22px;
background-color:#4F5972;
color: #FFF;}
#UpperContent {
margin:0;
padding:0;
background-color:#CABA66;
min-height: 200px;}
#LowerContent {
margin:0;
padding:0;
background-color: #FFF;
min-height: 200px;}
#footer {
margin:0;
padding:0;
min-height:100px;
border-top:4px solid silver;
/**RE-USABLE CLASSES**/
.section {
width:920px;
margin:0 auto; /**with width, this is centered on screen**/
padding:0 12px 0 12px;
.right {text-align:right}
.center {text-align:center}
/**FLOATS AND CLEARING**/
.floatLt {float:left; width:50%}
.floatRt {float:right;width:50%;
.floatRt:after, .floatLt:after {
visibility: hidden;
display: block;
font-size: 0;
content: " ";
clear: both;
height: 0;
/**TEXT STYLES**/
h1, h2, h3, h4, p {margin:0; padding:0}
#header h1 {
font-size:4.75em;
font-family:Tahoma, Verdana, Arial, Helvetica, sans-serif;
font-style: oblique;
color:#CABA66;
text-shadow: 5px 2px 5px #000;
/**shadows for IE**/
filter: dropshadow(color=#000000, offx=5, offy=2);
#header h2 {
margin-top:12px;
font-size: 1.75em;
color:#000;
margin-right: 240px;}
</style>
</head>
<body>
<!--begin header -->
<div id="header">
<div class="section">
header here...
<h1 class="center">Lapel High School</h1>
<h2 class="right">"Home of the Bulldogs!"</h2>
</div>
<!--end header --></div>
<!--begin navigation -->
<div id="nav">
Navigation menu here
</div>
<!--end navigation --></div>
<!--begin upper content -->
<div id="UpperContent">
<div class="floatRt">
<p class="right">Float right - upper content</p>
</div>
<p>Upper content...</p>
</div>
<!--end upper content --></div>
<!--begin lower content -->
<div id="LowerContent">
<p class="right">Float right - lower content</p>
</div>
<p>Lower content...</p>
</div>
<!--end lower content --></div>
<!--begin footer -->
<div id="footer">
<div class="floatLt">
<p>Float left - © 2012 footer text</div>
<p class="right">Float right - more footer text, blah, blah, blah, blah, blah...</p>
</div>
</div>
<!--end footer --></div>
</body>
</html>
Nancy O.
We have tried to replicate your page... this is our code
<head>
<link href="nancy_style.css" rel="stylesheet" type="text/css" />
STYLE SHEET
@charset "utf-8";
body {
font-family: Arial, Helvetica, sans-serif;
font-size: 1em;
background-color: #ffffcc;
margin: 0px;
padding: 0px;
color: #4f5972;
#header {
margin: 0px;
padding: 0px;
min-height: 100px;
#navbar {
color: #FFFFFF;
background-color: #0000CC;
margin: 0px;
padding: 0px;
min-height: 22px;
#upper_content {
background-color: caba66;
margin: 0px;
padding: 0px;
min-height: 200px;
#lower_content {
background-color: #FFFFFF;
margin: 0px;
padding: 0px;
min_height: 200px;
#footer {
margin: 0px;
padding: 0px;
min-height: 100px;
border-top-width: 4px;
border-top-style: solid;
border-top-color: #CCCCCC;
.section {
width: 920px;
margin-top: 0px;
margin-right: auto;
margin-bottom: 0px;
margin-left: auto;
padding-top: 0px;
padding-right: 12px;
padding-bottom: 0px;
padding-left: 12px;
.right {
text-align: right;
.center {
text-align: center;
.float_left {
float: left;
width: 50%;
.float_right {
float: right;
width: 50%;
.float_right:after {
font-size: 0px;
display: block;
clear: both;
height: 0px;
visibility: hidden;
.float_left:after {
font-size: 0px;
display: block;
clear: both;
height: 0px;
visibility: hidden;
#header_ h1 {
font-family: Verdana, Arial, Helvetica, sans-serif;
font-size: 4.75em;
color: #caba66;
#header_h2 {
font-size: 1.75em;
color: #00000;
margin-top: 12px;
</head>
<body>
<div class="section" id="header">Content for class "section" id "header" Goes Here</div>
<div class="section" id="navbar">Content for class "section" id "navbar" Goes Here</div>
<div class="section" id="upper_content">Content for class "section" id "upper_content" Goes Here
<div class="right">Content for class "float_right" Goes Here</div>
</div>
<div class="section" id="lower_content">Content for class "section" id "lower_content" Goes Here
</div>
<div class="section" id="footer">Content for class "section" id "footer" Goes Here
<div class="float_left">Content for class "float_left" Goes Here</div>
</div>
</body>
</html>
...and this is what it comes out to look like http://www.frankton-lapel.org/schools/lshs/baylor/background.html
Your CSS styles are commented out <-- STYLESHEET
This is how mine looks.
http://alt-web.com/TEST/LHS-test.html
Nancy O.
I took it out of the comment, here is the site that I tried to recreate using your css... http://www.frankton-lapel.org/schools/lshs/baylor/background.html
Any ideas on why my page is not reacting to the css like yours?
We really appreciate the help!
Because your HTML is completely different from mine. No shortcuts allowed for this type of layout.
<div id="header">
<p>Div id header, div class section goes here</p>
</div>
</div
<div id="navbar">
<p>Div id navbar, div section goes here</p>
</div>
<div>
<div id="upper_content">
<!--FLOATS COME FIRST-->
<div class="float_right">
<p class="right>Div id upper_content, div class section, div class float_right, p class right goes here</p>
</div>
<p>Upper_content goes here</p>
</div>
</div>
I think you get the idea. Good luck!
PS. check your CSS again, you're missing a # on one of your background-color values.
Nancy O.
