The Filename Template Editor and Text Template Editor
Apr 19, 2012 10:35 AM
    Apr 19, 2012 10:35 AM   in reply to Community Help
    Is there no way to change the font and size when this information is printed?
    Apr 19, 2012 10:27 PM   in reply to jackrumpole
    What information printed where?
    Apr 20, 2012 1:01 PM   in reply to Community Help
    When one prints a page of thumbnails with metadata text as chosen using the Text Template Editor it always comes out center-spaced in a sans-serif font at something like 10pts size and there seems to be no way to change this as far as I can tell.
    Apr 21, 2012 2:03 AM   in reply to jackrumpole
    No, you can only change the font size as described here.
    Apr 21, 2012 7:19 AM   in reply to Dorin Nicolaescu-Musteață
    Thank you. That answers my question. And knowing at least how to change the font size helps a little.
    ___
    Alan Graham McQuillan
    amcq@studio7190.com
    www.galleryMontana.com
    ___
    Aug 26, 2012 6:41 PM   in reply to Community Help
    Is there anyway to use a column from an Excel file to use as filename in tethered capture?
    This may be useful when taking photos of a group of person which have a list of their name, for example, students.
  • Victoria Bampton
    Apr 1, 2008
    Aug 27, 2012 10:50 AM   in reply to hmdiy
    Hi hmdiy.  No, there isn't.  There are probably some very roundabout workarounds using a combination of plug-ins.  Are you only shooting one picture of each person?  And are you doing this often?
    Aug 27, 2012 5:47 PM   in reply to Victoria Bampton
    Hi Victoria
    Thank you very much for your reply. I take one pic for each person, if I find it not good I will take another one immediately. I do this at least once a year but I take almost one thousand pics each time because I do this for the whole school.
    Thanks for sharing.
  • Victoria Bampton
    Apr 1, 2008
    Aug 28, 2012 1:25 AM   in reply to hmdiy
    There's a plug-in called LR/Transporter which will allow you to import data from a csv file.  http://www.photographers-toolbox.com/products/lrtransporter.php
    The theory would be something like this:
    Shoot tethered as normal, with a standard sequence number filename (i.e. 0001-1000)
    Create a csv file with sequence number (0001-1000) as one column and student name for the other column
    Use that plug-in to match up the csv sequence number column with the current filenames, and copy the student name data to a field that LR can use for renaming (i.e. Title or Caption)
    Batch rename the files set to the Title/Caption field containing the student name
    I'm sure you can come up with a more effective workflow (you may not even need to rename, just importing the data may be enough) but you get the idea?
    Aug 28, 2012 3:19 AM   in reply to Victoria Bampton
    Hi Victoria
    Thank you very much for your info. i tried to reply you at the forum but is out of service so reply you via email. Roughly I understand the idea but have to figure out and try first.
    All the best!
    E T
    豈能儘如人意,
    但求無愧於心!
    問為何常存空想  愁病誰可免
    是眾生必須經過   四苦根本是平常
    Date: Tue, 28 Aug 2012 02:25:35 -0600
    To: twtai@hotmail.com
    Subject: Re:  The Filename Template Editor and Text Template Editor The Filename Template Editor and Text Template Editor
        created by Victoria Bampton in Photoshop Lightroom - View the full discussion
    There's a plug-in called LR/Transporter which will allow you to import data from a csv file.  http://www.photographers-toolbox.com/products/lrtransporter.php The theory would be something like this: Shoot tethered as normal, with a standard sequence number filename (i.e. 0001-1000)Create a csv file with sequence number (0001-1000) as one column and student name for the other columnUse that plug-in to match up the csv sequence number column with the current filenames, and copy the student name data to a field that LR can use for renaming (i.e. Title or Caption)Batch rename the files set to the Title/Caption field containing the student name I'm sure you can come up with a more effective workflow (you may not even need to rename, just importing the data may be enough) but you get the idea?
         Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: Re:  The Filename Template Editor and Text Template Editor
         To unsubscribe from this thread, please visit the message page at Re:  The Filename Template Editor and Text Template Editor. In the Actions box on the right, click the Stop Email Notifications link.
         Start a new discussion in Photoshop Lightroom by email or at Adobe Forums
      For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
    Jan 1, 2013 4:05 AM   in reply to Community Help
    In Lightroom, I want to rename my images, based upon the image name and its mapping in a CSV file. Ideally, I would want something like this:
    http://i.stack.imgur.com/9kko4.png
    When the user after editing goes to Export under File menu. Inside the File Naming panel above, one should be able to input the CSV file containing the mapping. Hence once exported, the new Images will be named consistently with what I need rather than the default ones provided by LightRoom.
    Using the plugin LRTransporter one can do it while Importing images (storing the new name under Caption and then renaming all using Batch Rename). But it is tedious.
    What I need to know is that, can we build such plugin which can do it? Does the SDK provide access to do it? If yes I would move ahead with constructing it.
    Jan 1, 2013 4:13 PM   in reply to purijatin
    Consider posting in the Lr SDK forum.
