help!
Apr 19, 2012 11:41 AM
Tags: #photo #elements #create #7
I am trying to create a photo in elements 7. It is one single photo merged into three frames and the frames are all crooked and look transparent i guess... please help  got the pic from http://www.ashedesign.com/
    Apr 19, 2012 12:50 PM   in reply to sullivanjami
    1. Open picture file
    2. Open a blank layer above the background layer
    3. Access the rectangular marquee tool and drag out a suitably sized rectangle
    4. Go to Edit>stroke (outline) selection, position:inside, black color
    5. Access the Effects palette, select drop shadow - low - apply
    6. Go to Select>deselect
    7. On the layer with the stroke, double click the fx in the layers panel to bring up the Style settings dialog. Adjust the drop shadow and add an inner glow. Use the sliders.
    8. Duplicate this layer twice
    9. Access the move tool, and move the frames on the last 2 layers so that they are in the desired position. Note the little arrow to rotate the layers to get them off center as you hover adjacent to the frame
    Apr 19, 2012 1:48 PM   in reply to sullivanjami
    Please post one of your pictures after you have applied the frames. Tell me specifically what you want to get rid of.
    Will get back to you once I see it
    Apr 20, 2012 4:23 AM   in reply to sullivanjami
    Try this:
    1. Open your picture file
    2. Duplicate the background layer, work on the background copy layer. Shut off visibility of the background layer by clicking on its eye icon
    3. Open a levels adjustment layer and use the sliders to enhance the picture (esp. left slider)
    4. Merge down. leaving you with background and background copy layers
    5. Access one of the selection tools. I used the magnetic lasso tool, and selected around the boxes and the boy's feet
    6. Go to Layer>new>layer via copy to put the selection on its own layer
    7. Open a blank layer below this layer and fill with 50% gray (Edit>fill layer>50%gray), and drag a gradient on this layer while holding down the shift key, from below up. You can use any background to suit. I used the soft gradient for demonstration.
    8. Go back to the layer created in step #6, and sharpen slightly (Enhance>unsharp mask, 96, 0.7,1)
    9. Highlight the top layer, and place a blank layer above this, then press CTRL+SHIFT+ALT+E to create a stamp visible layer
    10. Go to Select>all, then Edit>stroke to place a "frame" around the entire thing.
    Please report back with your progress.
    Apr 20, 2012 4:48 AM   in reply to hatstead
    hatstead,
    What is the purpose of the 50% grey fill in step 7?  When I apply a gradient with and without the grey fill I get the same results.
    Apr 20, 2012 5:34 AM   in reply to Mark Sand
    I like to set this up in my work-flow so that painting ( if desired) pure white or black on a 50 percent gray overlay layer can produce high-contrast results. As this drill evolved, it is not necessary for a salutary result.
    Apr 20, 2012 10:47 AM   in reply to sullivanjami
    I took a slightly different approach (as well as a slightly more interesting subject ).
    Here's the original:
    1. Add three new layers to hold the frames.  Name them "box top", "box middle", and "box bottom".
    2. With the "box top" layer active, drag out a selection.
    3. Re-size and position the selection.
    4. Use Edit...Stroke (Outline) Selection.  I used 5px white.
    5. Repeat steps 2-4 for the other frame layers.  N.B.:  When a line is on a diagonal, it will appear to be slightly wider than a horizontal or vertical line, so I used a 4px width for the stroke.
    6. Duplicate the background layer three times.
    7. Place a duplicate of the background beneath each frame layer.
    8. With one of the frame layers active, use the Magic Wand with "Contiguous" selected to select the interior of the frame.
    9. Use Select...Modify...Expand and expand the selection by half the number of pixels used for the frame width so the selection will be within the frame.
    10. Make the duplicate image below the frame active.
    11. Use Select...Inverse, then hit your Delete key to remove the areas of the image that are outside the frame.
    12. Repeat steps 8-11 for the other frame layers.
    13. Apply a layer style to the frame layers, if desired.  I used a Simple Emboss.
    14. To change the colours of the frame, add a Hue/Saturation adjustment layer to each frame layer, clipping it to the layer and using the "Colorize" option.
    15. Select each image layer and apply a drop shadow effect, if desired.
    16. Add a new layer at the bottom of the stack and place a background of your choice on it, modifying it to suit.
    The final image:
    The layers look like this:
    That gives the most flexibility for modifying the effects, etc.
    Ken
    Apr 20, 2012 12:41 PM   in reply to sullivanjami
    Great job, Ken !!
    Apr 20, 2012 2:26 PM   in reply to Mark Sand
    Thanks, Mark; but be honest -- it's not me but the model!
    Ken
    Apr 21, 2012 10:10 AM   in reply to sullivanjami
    Jami,
    I assume you are referring to Ken's last method. I had to switch steps 2 and 3 to get it to work:
    2. Use Edit...Stroke (Outline) Selection.  I used 5px white.
    Also, if you intend to apply a layer style to the frame it doesn't matter what color you use when you do the stroke. Default black or white will work as well. The layer style overrides the color.
    Another thing I found when playing around with the instructions... If you simply want a plain frame without a layer style, if you do a large stroke with the Outside or Center option the corners of the frame will be rounded or chopped off depending on the stroke size. If you want square corners do the stroke Inside. In this case you will want to make the initial selection larger to account for the inside frame.
    In the top frame I did the stroke Outside; the corners are chopped off.  In the bottom frame I did the stroke Inside.
    Apr 21, 2012 11:49 AM   in reply to sullivanjami
    Jami,
    I'm using PSE10, and after making a rectangular selection there is the option of using Select...Transform Selection to move and resize the selection.  If that option isn't available in your version of PSE, then Mark's instruction is the way to do it -- outline the selection, which will create an object that the Move tool can manipulate.
    Mark,
    You're exactly right about the stroke's corners being rounded if not placed "inside" the selection.  Thanks for pointing that out.  It's a bug I wish Adobe would fix.
    I found that there were slight differences when using a H/S adjustment layer to colorize the frame, depending on whether the initial stroke wasn't coloured (black or white) vs. an initial colour (like blue).
    Ken
