We are using Acrobat Pro X and are haveing problems with Forms, when the form is opened and filled in there is a field number that obsures the content of the field. Is there a way to remove these numbers from the form or a way to set Acrobat Pro X to not display the numbers on a form field. We do not see this problem when using Adobe Reader 10.5
This forum is for the Adobe FormsCentral (formscentral.adobe.com) which is a service that allows you to create, collect and analyze data using an online web form. You should ask PDF related form questions in the Acrobat forums: http://forums.adobe.com/community/acrobat/forms
I'll move your post to that forum so you don't need to retype it. They can help you out...
Randy
I am only opening the document that is a PDF Form with Adobe Acrobat Pro X and I get these numbers on the form fields. I don't have any tools selected other than opening the document with the default settings on Acrobat Pro X. Where do I look to change the settings that is causing these numbers to be displayed?
