Hello,
Is there a way to use variables in regular expressions?
Can't find the right syntax.
var pattern = RegExp('/\n\d\t[^\t]+\t\d\t/' + var);
This does not work.
Michel
Hi Michel,
By 'variable' you mean any expression which can be coerced into a String, right? The point is to clearly make a distinction between a regex pattern (which is a string) and the RegExp instance itself:
var myString = "Hello";
var myPattern = "\\n\\d\\t[^\\t]+\\t\\d\\t" + myString;
var myRegex = new RegExp(myPattern, 'g');
// myRegex is then equivalent to: /\n\d\t[^\t]+\t\d\tHello/g
Note that all regular expression metacharacters such as \n or \d must be double-escaped when you introduce them through a literal string (cf. myPattern declaration).
Marc
