CQ5
bvibor
osgi workflowprocess gives classnotfound exception when osgi bundle is activated
Apr 19, 2012 12:34 PM
Tags: #exception #cq #day #osgi #classnotfound #workflowprocess
I did create an osgi service that extends workflowprocess interrface using eclipse. I install the bundle that contains this service and then deploy and activate the bundle in day cq. However, on activation I receive an error stating that my class is not found. Please note that both this service and the referenced service(twitterservice that I created) gets registered and the bundle is activated, however, its unable to find the class SendMessageProcessAction on the activation of the bundle. Hope someone could assist.
POST /system/console/bundles/246 HTTP/1.1] com.day.twitter.workflow [com.day.twitter.service.impl.SendMessageProcessAction] Error during instantiation of the implementation object (java.lang.ClassNotFoundException: com.day.twitter.service.impl.SendMessageProcessAction not found by com.day.twitter.workflow [246]) java.lang.ClassNotFoundException: com.day.twitter.service.impl.SendMessageProcessAction not found by com.day.twitter.workflow [246]
    at org.apache.felix.framework.ModuleImpl.findClassOrResourceByDelegation (ModuleImpl.java:787)
    at org.apache.felix.framework.ModuleImpl.access$400(ModuleImpl.java:71)
package com.day.twitter.service.impl;
import javax.jcr.RepositoryException;
import javax.jcr.Session;
import org.apache.felix.scr.annotations.Component;
import org.apache.felix.scr.annotations.Properties;
import org.apache.felix.scr.annotations.Property;
import org.apache.felix.scr.annotations.Reference;
import org.apache.felix.scr.annotations.Service;
import org.osgi.framework.Constants;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import com.day.cq.workflow.WorkflowException;
import com.day.cq.workflow.WorkflowSession;
import com.day.cq.workflow.exec.WorkItem;
import com.day.cq.workflow.exec.WorkflowData;
import com.day.cq.workflow.exec.WorkflowProcess;
import com.day.cq.workflow.metadata.MetaDataMap;
import com.day.twitter.service.SendMessageProcess;
import com.day.twitter.service.TwitterService;
@Component
@Service
@Properties({
    @Property(name = Constants.SERVICE_DESCRIPTION, value = " An example of Social Publish Implementation"),
    @Property(name = Constants.SERVICE_VENDOR, value = "RIM POC"),
    @Property(name = "process.label", value = "RIM POC Social Publish")
public class SendMessageProcessAction implements WorkflowProcess{
    @Reference
    private TwitterService twitterService;
    public TwitterService getTwitterService() {
        return twitterService;
    public void setTwitterService(TwitterService twitterService) {
        this.twitterService = twitterService;
     * @scr.reference
    private static final String TYPE_JCR_PATH = "JCR_PATH";
    private final Logger logger = LoggerFactory.getLogger(this.getClass()
            .getName());
    private final Logger logger1 = LoggerFactory.getLogger(SendMessageProcessAction.class);
    public void execute(WorkItem workItem, WorkflowSession workflowSession,MetaDataMap args)
    throws WorkflowException {
        final Session session = workflowSession.getSession();
        final WorkflowData data = workItem.getWorkflowData();
        logger.info("TEST VIBHOR!!");
        logger1.info("TEST VIBHOR BHATIA!!");
        String path = null;
        String type = data.getPayloadType();
        if (type.equals(TYPE_JCR_PATH) && data.getPayload() != null) {
            String payloadData = (String) data.getPayload();
            try {
                if (session.itemExists(payloadData)) {
                    path = payloadData;
            } catch (RepositoryException e) {
                // TODO Auto-generated catch block
                logger.error("Exception - Check repository for Payload data path");
                e.printStackTrace();
        logger.info("arguments");
        String msg = "CQ5 workflow event";
            // is there a message?
        String argument = args.get("PROCESS_ARGS", "default value");
        boolean equal = argument.equals("argument1");
        if(equal){
            String recipient = argument.toString();
             sendDirectMessageOnTwitter(recipient, msg, path);
        } else {
            logger
                    .error("for sending a DM on Twitter (make sure Twitter allows you to DM that account): dm,(recipient id)");
           //  return "Check config - error";
    private void sendDirectMessageOnTwitter(String recipient, String msg, String path) {
        getTwitterService().sendDirectMessage(recipient, msg + ", path: " + path);
    Apr 19, 2012 12:43 PM   in reply to bvibor
    How is your pom.xml lool like ?
    Apr 19, 2012 1:06 PM   in reply to bvibor
    How are you using SendMessageProcessAction in com.day.twitter.workflow ? using service reference ?
    Apr 19, 2012 1:25 PM   in reply to bvibor
    using
    @Reference
        private SendMessageProcessAction sendMessageProcessAction;
    But ideally you should expose interface than actual class. Can you post code for com.day.twitter.workflow ?
    Yogesh
    Apr 19, 2012 2:03 PM   in reply to bvibor
    From com.day.twitter.service.impl.SendMessageProcessAction not found by com.day.twitter.workflow it looks like com.day.twitter.workflow is trying to access SendMessageProcessAction. Can you post code for com.day.twitter.workflow
    Apr 19, 2012 2:18 PM   in reply to bvibor
    Can you try to put com.day.twitter.service.impl.SendMessageProcessAction in export section of your pom.xml
    Apr 19, 2012 4:45 PM   in reply to bvibor
    Can you put your package and let us know steps to reproduce ?
    Yogesh
    May 11, 2013 5:48 AM   in reply to bvibor
    one of the workaround is by adding -XX:-UseSplitVerifier option to the JVM .This issue seems to be an with CQ 5.6 and java 7
    May 11, 2013 5:48 AM   in reply to Avinashtan
    This issue arrises due to @Reference
