Temujin1848
Indesign CS5.5 hang on loss of focus when opening files
Mar 14, 2012 9:45 AM
Tags: #error #indesign #5.5
I know there's going to be no quick fix but I'm going to throw this out. InDesign CS5.5 / 7.5.2 running on WindowsXP SP3 seems to hang when the program looses focus when a file is opened. The program will ocassionally lose focus if you click on the "update" button or if you select another application/window. The result is that the file will open but InDesign does not allow any actions. Just a "ding" when you click anywhere.
Besides the obvious "don't touch your computer", any fixes/ideas? Hang on update is really annoying, especially if you don't touch anything except the update button.
    Apr 17, 2012 12:29 AM   in reply to Temujin1848
    First thing I would try is repalcing your prefs. Might not help, but it's pretty painless. See Replace Your Preferences
    Apr 18, 2012 1:06 PM   in reply to Temujin1848
    Are you by any chance working on the dual monitor ?
    Apr 18, 2012 2:22 PM   in reply to Temujin1848
    Manish is on the right track, I think. It only "seems" to hang. I personally would be dubious about running CS5.5 on WinXP, but when I was running CS2 and CS3 on WinXP I frequently experienced your exact issue - because there was a hidden dialog that I couldn't bring to the front, because the main ID window was locked by the dialog, and the dialog couldn't be dismissed with the keyboard.
    It was a long time ago, so I don't recall which solution worked for me. I think I used MultiMon Taskbar to send the dialog to the other monitor where I could get at it. However, I know that ding quite well, and I'm pretty sure that ID isn't hung. Maybe Manish has a solution ready to go?
    Apr 19, 2012 6:57 AM   in reply to Joel Cherney
    What joel said is right....
    May be there is a Indesign dialog box which is popping up on the other monitor , hidden behind any other window , there are dialog boxes which pop up on the screen and are mandate , In these cases you will hear the ding and also the application would loose focus because at that time the dialog box is primary windows.
    Also you wrote that the issue is at File-->open , does it also happen when you create the new file, if not then it could be windows link Missing fonts , Missing Links etc which could be popping on second monitor while opening the file.
    you can try changing the primary monitor to other one.
    Also you can check any dialog box popping up.
    Apr 19, 2012 3:47 PM   in reply to Temujin1848
    There's a 100% chance that the file will open without hanging InDesign if I do NOT update any links, but click the "update" button drops the success rate down to 50%.
    I suspect that means that 50% of your InDesign files only need links updated (but ID knows where they are), while in the other 50% of your files, the links are missing or moved or rename, and your file-browser window (that gets spawned when you click "Update" but ID can't find one or more of your linked files)  is behind your main InDesign window.
    To prove this to yourself: Drop the second monitor for a few minutes. Unplug it entirely, go back to using just one monitor. Then use InDesign as you would ordinarily. Try to open your files. I feel pretty confident that you would experience 0 hangs-with-dings-whenever-you-try-to-click-anywhere-in-ID.
    Apr 19, 2012 11:50 PM   in reply to Temujin1848
    Question still stand....does it happen when you create new file?
    forget about opening the file.....just create a new one , a fresh file ...save it and re-open it.
    And yes what Joel said , disconnect one monitor and then check , it will sort the problem for sure as it will let you know what exactly is happening.
