Don26812
PSE 8 catalog in custom location not shown in catalog list
Apr 18, 2012 3:15 PM
I am trying to help a client recover from a computer problem. She was having several types of problems with her PC a couple of months ago. PSE 8 seemed to be working ok at the time, and my memory tells me I Reconnected all missing files (if there were any), Repaired and Optimized, as is my usual practice. I then did a full backup to an external drive. She then had her son fix her computer in some way shape or form. He lives out of state. I got a call and she said she was ready for me to get her PSE 8 back up and running.
When I got there, we discovered she did not have the PSE 8 CDs. She he bought it online from Adobe but never copied it to a CD etc. We decided she would buy PSE 10 and download it. I had never downloaded any from the Adobe Store and was totally shocked to discover it was a three hour download. Other equally large files I have downloaded from Adobe would have taken 20-30 min. While it was downloading I even went hoe and started the download on my internet connection. It would have taken an equal amount of time. Sorry, I strayed.
After we installed PSE 10, I did a Restore from the PSE 8 backup I made a couple of months ago. I have done this many times over the years with very good results. We got a message saying the catalog was successfully restored. But when I went to convert it to PSE 10, an error appeared saying the conversion failed and we shoulf try restoring it on to PSE 8 and try abother Backup.
That's the background. I do still have PSE 8 on a PC at home. I restored the Catalog to a custonm location (a second internal drive). All of the 5300 pictures or visible, tags appear to be in order etc.
But before trying a Back-up I wanted to Repair and Opimize the Catalog (named my Catalog). But with the catalog visible, the area where I expected to see [Current] is blank, and the Repair etc buttons are grayed out. I'm stumped. The only think I can think to do is to back another backup and try to restore that one on her PSE 10 after I dry run it at home.
I'f attached a screen shot showing the dialog box in quesation. I now see where it is quite small, you should be able to see the areas of the screen I'm referring to.
I'm stumped. Any suggestions will be very much appreciated.
    Apr 18, 2012 5:23 PM   in reply to Don26812
    Change your custom path by moving it up one level to the parent folder. So do look at the path "K:\Renee\MyCatalog" and instead look at "K:\Renee".
    Apr 19, 2012 1:40 PM   in reply to Don26812
    That is indeed strange behavior. Also, it looks like you had the correct path the first time.
    I haven't seen behavior like this before, but the first thing that comes to mind is that the settings files may have become corrupted. Let's take a look at resetting them and see if that corrects the behavior.
    1. Close Elements Organizer
    2. Go to:
    --Windows XP: C:\Documents and Settings\[User Name]\Application Data\Adobe\Elements Organizer
    --Win Vista/7: C:\Users\[User Name]\AppData\Roaming\Adobe\Elements Organizer
    3. Rename the folder "8.0" to "8.0old"
    4. Retry Elements Organizer
    If this doesn't work, delete the new 8.0 folder and rename 8.0old back to 8.0.
    Apr 19, 2012 4:04 PM   in reply to Don26812
    OK, still not sure what's going on yet, but still more stuff to look at and try.
    First, did you have a version of Photoshop Elements before version 8?
    Also, can you navigate to K:\Renee\MyCatalog and tell me what files/folders you have there?
    Apr 20, 2012 8:08 AM   in reply to Don26812
    Thanks for the screen shot. The main reason I wanted to see this was to verify that your catalog was for this version. Which it is. It's hard to tell from the screen shot, but it looks like the catalog file has been set to "hidden". The icon looks semi-transparent. While you can turn on settings in Windows Explorer to view "hidden" files, it would still be hidden from applications. Which wouldn't prevent it from being used.
    So try this:
    1. Right-click on "catalog.pse8db" and choose Properties.
    2. Verify whether the "Hidden" option is checked. If it is, uncheck it and click OK.
    3. Retry checking File>Catalog in Photoshop Elements.
