real number returned with comma as decimal delimiter
Apr 17, 2012 11:44 AM
I have CF9 installed on W7 using an Access database.
In a table I have a currency value of
-488.7
The windows is French, but I have set the delimiter for both the decimal values AND currency values to dot instead of comma.
Though I get this error in CF:
The value -488,7 cannot be converted to a number.
CF is receiving the value with a comma instead of a dot.
- If I browse the table under Access, the value is correctly displayed with a dot.
- If I modify the column type to teTEXT instead of real or currency, the value is converted to text with a dot, and there is no error in CF.
Obviously a conversion from dot to comma is made in some other layer, but where?
I've checked in the ODBC connection and found nothing.
Any idea?
    Apr 18, 2012 6:03 AM   in reply to Claude
    If you do a simple query and cfdump the result, do you get a period or comma?
    Apr 18, 2012 10:57 AM   in reply to Claude
    You mean you had a query like this:
    select some_text_field, etc
    union
    select some_numeric_field, etc
    that didn't error out?
    I just tried that in redbrick and sql server and in both cases, they crashed.
    Apr 19, 2012 8:42 PM   in reply to Claude
    Kind of weird indeed, you're right, it should cause an error.
    Databases frequently do implicit conversion on string values.  So I would not expect an error unless the string could not be converted to the numeric data type its being merged with. That is how it works in sql server. For example, this automatically converts the string '0' to numeric (or whatever data type is used)
             SELECT '0' AS Test
             UNION
             SELECT cast(10.50 as numeric(10,2))
    Message was edited by: -==cfSearching==-
