Day CQ installation problems
Apr 19, 2012 4:00 PM
Tags: none (add) #command #installation #prompt #cq #connect_exceptionHi Group,
I am facing issues while running the CQ 5.4 jar on Win 7 with java 1.5.When I launch the jar directly nothing pops up and no installation starts.If I run it from the command prompt I get an error as mentioned below:
Please note that the 4502 port is available and is successfully bound as it appears in the log.I however see a ConnectException while connecting to the CRX during the installation.
Kindly help me resolve this issue.
CONSOLE LOG:
D:\day\cq5\author>java -Xmx512m -jar cq-author-4502.jar
Loading instance properties:/quickstart/quickstart-cq5.properties
Running on a console, won't fork the JVM (use -fork to force forking)
Using 32bit VM settings
The JVM reports a heap size of 508 MB, meets our expectation of 256 MB +/- 20
The JVM MBean:Perm Gen reports a maximum size of 64 MB, meets our expectation of 64 MB +/- 20
Setting system properties from filename 'file:/D:/day/cq5/author/cq-author-4502.jar'
System property '-crx.quickstart.server.port' set to '4502' from filename cq-author-4502.jar
System property 'sling.jcrinstall.folder.name.regexp' set to '.*/(install|config)(.author)?$' from filename cq-author-4502.jar
System property 'sling.run.modes' set to 'author' from filename cq-author-4502.jar
System property 'server.ready.url.1' set to '900/120/0 http://localhost:$PORT$/login.html .*(QUICKSTART_HOMEPAGE|CRX_LICENSING_PAGE).*' from filename cq-author-4502.jar
System property 'server.ready.url.2' set to '300/40/0 http://localhost:$PORT$/libs/cq/core/content/systemready.txt .*(QUICKSTART_HOMEPAGE|CRX_LICENSING_PAGE).*' from filename cq-author-4502.jar
System property 'com.day.crx.launchpad.filters.CRXLaunchpadLicenseFilter.waitForConte ntPath' set to '/bin/login.html?src=CRXLaunchpadLicenseFilter' from filename cq-author-4502.jar
Verbose option not active, closing stdin and redirecting stdout and stderr
Redirecting stdout to D:\day\cq5\author\crx-quickstart\logs\stdout.log
Redirecting stderr to D:\day\cq5\author\crx-quickstart\logs\stderr.log
Press CTRL-C to shutdown the Quickstart server...
stderr.log
Quickstart startup at Thu Apr 19 15:35:08 IST 2012
crx.quickstart.build.number=5.4.0.20110218
DiskSpaceUtil.getMaxOpenFiles() reports a maximum of 2147483647 open files, meets our requirement (8192)
PortSelector: Selecting server port from supplied list: 4502
PortSelector: Trying port 4502
PortSelector: Successfully bound to port 4502, will use it
PortSelector: Selected port 4502
etc/server.xml does not exist, CQSE password not saved
quickstart.properties not found, not an update
PreserveExistingFiles: no files to restore from pre-upgrade backup
System property crx.quickstart.info.jar.name set to file:/D:/day/cq5/author/cq-author-4502.jar
System property crx.quickstart.info.work.dir set to D:\day\cq5\author\crx-quickstart
System property crx.quickstart.info.server.dir set to D:\day\cq5\author\crx-quickstart\server
System property crx.quickstart.info.server.port set to 4502
Extracting CQSE distribution...
Ignored as we're providing a Quickstart-specific variant: D:\day\cq5\author\crx-quickstart\server\server.bat
Ignored as we're providing a Quickstart-specific variant: D:\day\cq5\author\crx-quickstart\server\serverctl
Ignored as we're providing a Quickstart-specific variant: D:\day\cq5\author\crx-quickstart\server\start
Ignored as we're providing a Quickstart-specific variant: D:\day\cq5\author\crx-quickstart\server\stop
Saving build number in quickstart.properties
Setting up CQSE webapps and files...
13 files extracted from jar file
Extracting static files to workdir...
31 files extracted from jar file
Making scripts executable...
Running chmod +x D:\day\cq5\author\crx-quickstart\server\serverctl
Failed to set executable mode on scripts: java.io.IOException: CreateProcess: chmod +x D:\day\cq5\author\crx-quickstart\server\serverctl error=2
Processing updates...
Updates source: D:\day\cq5\author\crx-quickstart\repository\patches\new
RunJarOnce INFO: RunJarOnce created, srcFolder=D:\day\cq5\author\crx-quickstart\repository\patches\new, doneFolder=D:\day\cq5\author\crx-quickstart\updates\history
No update jars executed
Done processing 0 updates
sling.repository.url not set, empty in instance properties
Starting CQSE on port 4502, interface=null...
Work dir: D:\day\cq5\author\crx-quickstart
CQSE arguments: [-p, 4502]
System property server.ready.url.1 defines WaitUrlParams, url=http://localhost:4502/login.html, regexp=.*(QUICKSTART_HOMEPAGE|CRX_LICENSING_PAGE).*, times=900/120/0
System property server.ready.url.2 defines WaitUrlParams, url=http://localhost:4502/libs/cq/core/content/systemready.txt, regexp=.*(QUICKSTART_HOMEPAGE|CRX_LICENSING_PAGE).*, times=300/40/0
Waiting for http://localhost:4502/crx (0/900) ...
Waiting for server installation...
Retrying http://localhost:4502/crx (ConnectException) (1/900)...
Retrying http://localhost:4502/crx (ConnectException) (3/900)...
Retrying http://localhost:4502/crx (ConnectException) (5/900)...
Retrying http://localhost:4502/crx (ConnectException) (7/900)...
Retrying http://localhost:4502/crx (ConnectException) (9/900)...
Retrying http://localhost:4502/crx (ConnectException) (11/900)...
log4j:WARN No appenders could be found for logger (com.day.commons.httpclient.impl.ProxySelector).
log4j:WARN Please initialize the log4j system properly.
Retrying http://localhost:4502/crx (ConnectException) (13/900)...
Retrying http://localhost:4502/crx (ConnectException) (15/900)...
Retrying http://localhost:4502/crx (ConnectException) (17/900)...
Retrying http://localhost:4502/crx (ConnectException) (19/900)...
Retrying http://localhost:4502/crx (ConnectException) (21/900)...
Retrying http://localhost:4502/crx (ConnectException) (23/900)...
Retrying http://localhost:4502/crx (ConnectException) (25/900)...
MAIN process: shutdown hook
MAIN process: exiting
Saludos
Kartheek
