heres my dilema
i currently have 5 sprites and 5 different set co ordinates for each one to spawn into with individual behaviour scripts, however i want each sprite to spawn into one of the set co ordinate without more than one of them spawning into the same point.
so eventually each sprite will spawn into a random set co ordinate
so something like
pRandomStartingLoc = (200,100) (300,100) (400,100) so each sprite spawns into only one set of cordinates without more than one spawning into the same one
You want something like the following:
-- Random Set behavior
property pSetNum
property pMySet
On GetPropertyDescriptionList me
Props = [:]
Props[#pSetNum] = [#default:#1, #format:#integer, #Range:[#min:1, #max:5], #comment:"Choose a set."]
return Props
end GetPropertyDescriptionList
on beginSprite me
Case pSetNum of
1: pMySet = [point(200,100), point(300,100), point(400,100)]
2: pMySet = [point(200,100), point(300,100), point(400,100)]
3: pMySet = [point(200,100), point(300,100), point(400,100)]
4: pMySet = [point(200,100), point(300,100), point(400,100)]
5: pMySet = [point(200,100), point(300,100), point(400,100)]
end case
put pMySet
end beginSprite
Yes you would use one behavior for all five sprites.
You need to modify the code I wrote and add it to your behavior. And, of course each "pMySet" property in the case statement would be set to a different list of points.
The general idea is that if a set of sprites all have the same behavior but some of their properties need to be set to different values, then you use the " GetPropertyDescriptionList()" handler to set those differenct values.
I thought perhaps you were using some variation of the code Mister MUX wrote.
Here's a more complete version:
property pSetNum
property pMySet
property pSp
property pStartLoc
On GetBehaviorDescription me
return "Sets sprite to a random location based off a predefined set."
end GetBehaviorDescription
Props = [:]
return Props
on beginSprite me
pSp = Sprite(me.spriteNum)
-- get my location choice set
Case pSetNum of
-- *** Change these value to what you want *****
2: pMySet = [point(100,200), point(500,105)]
3: pMySet = [point(50,70), point(478,387)]
4: pMySet = [point(400,500), point(623,245)]
5: pMySet = [point(600,400), point(284,470)]
end case
pSp.loc = pMySet[random(pMySet.count)] -- set my location
pStartLoc = pSp.loc -- store current location in case you want to return to it
end beginSprite
on goToStartLoc me
pSp.loc = pStartLoc
end
thanks this worked for the spawning however they can still spawn into the same co ordinates?
eg i tried with 2 sprites
1: pMySet = [point(100,200), point(500,105)]
however set 1 and set 2 sprites still sometimes spawn into the same co ordinate? i want only one sprite in one co ordinate at a time
I'm not sure what you want. Is this closer?
property pPosNum
property pSp
property pStartLoc
Props = [:]
Props[#pPosNum] = [#default:#1, #format:#integer, #Range:[#min:1, #max:5], #comment:"Choose a set."]
return Props
on beginSprite me
pSp.loc = [point(200,100), point(300,100), point(400,100), point(500,100), point(600,100)][pPosNum] -- set my location
end beginSprite
on goToStartLoc me
pSp.loc = pStartLoc
end
Okay fourth time may be the charm.
This behavior contains a Single Locations list that is global to all sprites with this behavior attached. Each sprite picks a random loc from the list and then deletes that value from the list so that no other sprite can use it.
Note: This uses some advanced Lingo, but you should only need to replace the point values in the list of point values.
property pSp -- this sprite
property pStartLoc -- this sprites location at beginsprite
-- global/static behavior property
property curLocs -- list of sprite locations used by ALL sprites with this behavior attached
on beginSprite me
-- define our quasi global locations list if it is not defined or is empty
if me.script.curLocs.voidP OR me.script.curLocs = [] then
me.script.curLocs = [point(200,100), point(300,100), point(400,100), point(500,100), point(600,100)] -- Define Sprite Locs Here
end if
Locs = me.script.curLocs
pSp.loc = Locs[random(Locs.count)] -- set my location to random point from list
Locs.deleteOne(pSp.loc) -- remove this Loc from list so that no other sprite can use it.
-- debug code. Check message window
put "Sprite " & me.spriteNum & " is at location " & pSp.loc
end beginSprite
on goToStartLoc me
pSp.loc = pStartLoc
end
on endSprite me
me.script.curLocs = void
end
on reset me
me.endSprite()
me.beginSprite()
end
tried this with 2 objects using points [point(200,100), point(300,100)]
didnt work again, the objects were able to spawn at the same co ordinates
eg object 1 and object 2 both spawned at 200,100 when only one of them should have, then the other should have spawned at 300,100
EDIT IGNORE IT WORKED ![]()
pStartLoc holds the starting location point and you can use that to modify the code, or you can just call the goToStartLoc() handler. As in:
sprite(5).goToStartLoc()
sendAllSprites(#goToStartLoc)
Delete the "reset()" handler above. It will not work correctly. I would delete it from the forum but the forum won't let me at the moment.
I used the code above "sprite(5)goToStartLoc()" but changed the 5 to ch so I can have a universal code for all the cast members I am using, I used it to try make them respawn but they all respawned back onto the random coordinate it was assigned to i.e all to (300,100). I want it so a member who was at (400,200) will return to that exact coordinate and another member for example at (600,400) with return to that exact coordinate.
Any help will be appreciated.
this just sent all the sprites back to one random co ordinate, i want each sprite to return back to its each individual random cordinate that we used in the example code above
eg using your code before
me.script.curLocs = [point(200,100), point(300,100)]
if sprite 1 spawns at (200,100), sprite 2 spawns at (300,100). im creating a dragging game so if i drag the sprite 1 to a wrong location i want sprite 1 to return back to (200,100), however as you know sprite 1 could also spawn at (300,100) next time. so basically i want whatever random co cordinate the sprite spawns at the start, for it to return to that same given co cordinate if a given action occurs
