Tony Reynes
How do I place sequential serial numbers on images for export?
Apr 19, 2012 5:22 PM
Tags: #export #lr4 #serialization
I have a large job for a client who uses antique computers. They are so old that he can't run Lightroom. As a workaround, I posted the images I wanted him to look at on SmugMug and we had a disaster. Their sequencing on screen does not match my "as shot" sorting on my Lightroom (4). Is there a way I can print sequential serial numbers/ids on my images before I upload them to SmugMug so we are always talking about the same image?
  • Rusty Sterling
    Feb 21, 2007
    Apr 19, 2012 5:29 PM   in reply to Tony Reynes
    Yes. In the Export dialog box, under "File Naming"  check "Rename To" select "Custom Name -- Sequence" then type in your custom name and it will automatically add the sequence numbers to the files. I'd suggest you export these to a "specific folder."
    Apr 19, 2012 5:55 PM   in reply to Tony Reynes
    I don't think Rusty's recommendation will place the image name on the image. However, you can using print to file in the Print module. By checking the "Photo Info" option, then from the drop down options to the right, you can select Custom Name, or several other options of metadata to print on the image directly.
    Additionally you can take a look at the Mogrify export plugin ... it can do this via the Export process ... it is donationware so test it out before you donate in case it is not quite what you expected.
    http://photographers-toolbox.com/products/lrmogrify2.php
  • Rusty Sterling
    Feb 21, 2007
    Apr 19, 2012 11:39 PM   in reply to Butch_M
    Then, let the OP clear it up: Does he want a watermark with the file name and sequence number of it, or a filename that includes a sequence number.
    Frankly, creating a filename with a sequence number for each image would be alot easier; you can do it in the print module, and you still have to create a name plus sequence, and it should print a 1/XX, 2/XX, etc. on the images (make sure Photo Info is checked and you choose "Sequence" as an option). If you choose this option, be sure and select where you want the images (I would suggest Desktop) and once you click Print/Print LR will create a folder with the images all named and in sequence (in the file names) and also have the 1/xx, 2/xx, on the image file. You may have to play with the font color for the name printed on the image file, since it defaults to black. Just not sure if that is what you want vs. a unique filename for each photo.
    So exactly what, Mr. OP, are you looking for?
    Apr 20, 2012 12:51 PM   in reply to Tony Reynes
    You say "as shot," which may mean that the file names are already in sequence and they get scrambled when uploaded to Smugmug?  If so, just go to Arrange/Sort and sort on the file names.  You can also sort on time taken.
    Alternatively, and simpler, in Smugmug at the top of the gallery you have "1 of X" as in "1 of 31" images in this gallery, so just use that gallery number to talk about the right images.
    Apr 20, 2012 6:56 PM   in reply to Rusty Sterling
    Hey ... I wasn't causing trouble ... just pointing that the OP mentioned they wanted to ... "Is there a way I can print sequential serial numbers/ids on my images" ... and I offered options to do so ... sorry to intrude ...
