Stephan Specht
hyperlinks in pdf don't work
Apr 19, 2012 1:37 AM
Tags: #pdf #hyperlink #reference
Hi.
I create pdfs with hyperlinks in adobe indesign 5.5.
The created Hyperlinks refer to other pdf documents and still work,
but if I open the same pdf Files with another computer,
the links don't work.
I don't know why hyperlinks don't work on the other computer.
Any ideas?
Both Acrobat Versions have the ability to use and open linked documents.
It seems to be a general problem from acrobat.
    Apr 19, 2012 3:26 AM   in reply to Stephan Specht
    It isn't a problem of Acrobat.
    Apr 20, 2012 12:22 AM   in reply to Stephan Specht
    Did you create the links in InDesign or Acrobat?
    Apr 20, 2012 12:55 AM   in reply to Stephan Specht
    It's a known issue with InDesign - rather than creating "open file" link types, it creates URL links using a "file://" protocol on the address. These don't work if you change the locations of the file, e.g. by moving them to another computer.
    I can't comment on when it will be resolved, meanwhile you will have to create the links by hand in Acrobat, choosing the "open a file" action. It's not something which can be automated.
    Apr 20, 2012 3:37 AM   in reply to Stephan Specht
    No, a link has to point to a specific file (but the "open file" link type can refer to a relative path)
    Are Wildcards in Hyperlinks accepted in Acrobat or InDesign?
    -this could be useful to define the file location.
    Apr 20, 2012 6:47 AM   in reply to Stephan Specht
    If you create a link in Acrobat to another PDF file in the same folder or in a subfolder of the source PDF's location, the link destination will always specify only the filename (and optional subfolder), not the absolute path. Provided those two files/folders are moved together, the link will always work.
    EG:
    "Index.pdf" in folder  "C:\Writing\Novels\MyBook"
    "chapter.pdf" in "C:\Writing\Novels\MyBook\Chapters"
    Linking from "index.pdf" to "chapter.pdf", the filespec attribute of the link will be "Chapters/chapter.pdf".
    Copying the entire "MyBook" or "Novels" folder and subfolders to another computer, CD, etc. the link will work as normal.
