I have this script to find my desired text:
var myDoc = app.activeDocument;
// Creates service Text Frame
myDoc.textFrames.add({
geometricBounds: [50,-300,740,-70], fillColor: "C=100 M=0 Y=0 K=0", fillTint: 20, name: "Summary"
//Find text
app.findGrepPreferences = null;
app.findGrepPreferences.findWhat = "(.+\\r)(\\+.+$)";
found = app.activeDocument.findGrep ();
alert (found.length)
var new_grep = new Array()
for(a=0; a<found.length; a++)
new_grep[a] = found[a].contents
Now, what I'd like to know is how to paste the found text (the contents of new_grep) into my textFrame "Summary".
Additionally, I should erase substring #2 (\\+.+$) from the original frame...
Trying and trying but I can't find my way, I know, it should be damn simple...
Guido
After grabbing the contents, use the same GREP again on your document and replace with nothing.
Then put the copy of the found items into a frame like this:
summary_textframe.contents = new_grep.join("\r");
The other way around will not work because you act on 'the entire document', and you would erase it from your new frame as well.
I solved by myself with a FAR LESS elegant method:
app.findGrepPreferences.findWhat = "(.+\\r)(\\r\\+.+$\\r?)";
myFind = app.activeDocument.findGrep ();
var myCount=0;
for (i=0; i<myFind.length; i++)
myDoc.textFrames.item ("Summary").contents=myDoc.textFrames.item ("Summary").contents+myFind[i].contents+"\r";
myCount++;
Concerning the second part of the problem (erasing substring #2 from the main frame) I will simply perform a second find/change routine replacing the substring #2 with ()...
Is this correct?
Thank you, Jongware
Guido
You can set this up in the Next Paragraph style field per style. Then all you have to do is select all text and "Apply "This" style, then Next" from the Paragraph style menu. Way more easier than scripting it. (*)
(*) Not really, but it would be a script that duplicates something that's already available. I'm not falling for that.(**)
(**) Again. (I once wrote a large script and people wrote comments like "uh, isn' that just like command 'X' in the interface..?".)
Hi Jongware,
after a bit I returned to my script and, of course... it doesn't work anymore!
This is what I'm up to:
//Find text
app.findGrepPreferences.findWhat = "(.+\\r)(\\r\\+.+$ \\r)";
var myCount=0;
alert (myFind)
myCount++;
// Delete "+ foto"
app.findGrepPreferences.findWhat = "(\\r\\+ FOTO.+$)";
myDoc.selection[0].changeGrep();
The new frame is created, but nothing gets pasted in it.
I DO REMEMBER it used to work (that was before my hard disk crashed and I had to open my iMac to replace it...), God knows what I've done wrong.
Suggestions?
Thx,
g
Use the ESTK debugger, as described in today's thread http://forums.adobe.com/thread/991744?tstart=0
Ok, sorted out.
There was an error in the find query; it was:
app.findGrepPreferences.findWhat = "(.+\\r)(\\r)(\\+.+$ )\\r)";
There was a space before the last \r entry, so I solved with
app.findGrepPreferences.findWhat = "(.+\\r)(\\r)(\\+.+$( ?)\\r)";
because sometimes THERE IS a trailing space at the end of the paragraph.
Now, in order to paste only subpatterns #1 and #3 in the new frame, should I do:
//Find text
app.findGrepPreferences = app.changeGrepPreferences = null;
app.changeGrepPreferences.changeTo = "$1\\r$3"
...maybe?
The subpattern replacement and changeTo property only work with changeGrep, which means that you would change them in your actual document.
The only way to get what you want is to do your findGrep, then make a new array containing just the text (because the result from findGrep points directly to your actual live text) -- your original array "new_grep" method in your first post is fine. In this copy, you can use regular Javascript string functions to re-arrange the text to your like. After that you can paste the processed text into a new frame.
For example, to get rid of the single space at the end of a paragraph in Javascript, you could do something like this:
new_grep[i] = new_grep[i].replace (/ \r/g, '\r');
-- if there is nothing to replace, the string will be unchanged.
Uh, Google? I'm not aware of any specific sites ...
I think I learned all of my Javascript GREP knowledge from this very forum, precisely this same way you encountered it just now: someone using these expressions in an otherwise unrelated script. I'm sure there is nothing in Adobe's JS guides about this particular subject.
In any case, you must certainly not include "indesign" in your google query. InDesign's own GREP is very different from Javascript's (a subject leading to much confusion).
Found something, thank you. The problem was I was googling with "InDesign" in the query, as you said...
Anyway, now my simple script:
//Find text
app.findGrepPreferences.findWhat = "(.+\\r)(\\r)((\\+.+$( ?)\\r)+)";
new_grep[a] = found[a].contents;
var Summary = myDoc.textFrames.item ("Summary")
Summary.contents = new_grep.join("\r");
Stops at line 3, - myDoc.textFrames.add - saying "undefined is not an object... I can't think nothing more vague than this...
g
So, /g means "Apply this globally"
But I'm having other difficulties applying your line
new_grep[i] = new_grep[i].replace (my find/replace query here);
in my script.
If I write it that way, ESTK responds with "new_grep.replace is not a function" (I guess the problem is in the parenthesis).
g
Does your new_grep array contain plain text, as it did in your initial post? I.e., are you filling it with the result of your GREP search as you did?
The .replace function only works on Javascript strings. Copying 'contents' to a new array makes sure it gets translated to a JS string, and you cannot use it on a native InDesign Text object (which is the kind that findGrep itself returns).
