Code Question
Apr 20, 2012 5:21 AM
Hi, I'm using Flash CS5 and actionscript 3 and going through a "bouncing ball" tutorial from a book that I bought.
The ball is supposed to bounce around a window indefinately.
The example works but instead of the ball keeping within the boundaries of the window it floats off the screen never to return.
Can someone please have a look at the code below and tell me what I can add to make this work as described?
Thank you very much.
package {
    //Import necessary classes
    import flash.display.MovieClip;
    import flash.events.Event;
    import flash.geom.ColorTransform;
    import flash.geom.Rectangle;
    public class Ball extends MovieClip {
        //Horizontal speed and direction
        public var speedX:int = 10;
        //Vertical speed and direction
        public var speedY:int = -10;
        //Constructor
        public function Ball() {
            addEventListener(Event.ENTER_FRAME, onEnterFrame);
            //Colors the ball a random color
            var colorTransform:ColorTransform = new ColorTransform();
            colorTransform.color = Math.random()*0xffffff;
            transform.colorTransform = colorTransform;
        //called every frame
        private function onEnterFrame(event:Event):void{
            //Move ball by appropriate amount
            x += speedX;
            y += speedY;
            //Get boundary
            var bounds:Rectangle = getBounds(parent);
            //Reverse
            //of stage.
            if (bounds.left < 0 || bounds.right > stage.stageWidth) {
                speedX *= -1;
    Apr 20, 2012 5:56 AM   in reply to Winston2
    It looks like you do not have anything to keep the ball within the boundaries for the y side of the story, only the x.  You need to have something for speedY just like you do for speedX where you check the bounds.top and bounds.bottom...
                if (bounds.top < 0 || bounds.bottom > stage.stageHeight) {
                    speedY *= -1;
