thunderxlight11111
adding and removing child
Apr 19, 2012 7:58 AM
hi how are you guys ?i hope you all fine .
iam trying to understand how add and removing child work and i did this  short code
here how its work
1-the main stage is empty nothing in it
2- in the library there is class called (MAINMAP1)  the only class in the project
3- i did 2 codes in the (MAINMAP1) class ,  the first didn.t  work and the other  work.
4- iam running from the main stage.
here
the first code
package
import flash.system.System;
import flash.system.fscommand;
    import flash.display.MovieClip;
import flash.media.Sound;
    import flash.media.SoundChannel;
    import flash.events.KeyboardEvent;
    import flash.ui.Keyboard;
    import flash.events.Event;
    import flash.events.MouseEvent;
    import flash.display.Stage;
public class MAINMAP1 extends MovieClip {
  public function MAINMAP1(){
    MovieClip(parent).addChild(this);
it doesn.t add any thing in the main stage it still empty
but the other work (when i added instance of the map class to the main stage this code remove it)
package
     MovieClip(parent).removeChild(this);
thats all
i hope you guys can help  me
thank you
    Apr 19, 2012 8:44 AM   in reply to thunderxlight11111
    in the first example you gave
    when you construct MAINMAP1 it tries to add itself to its parent.
    but it's doesn't have a parent yet cause you haven't added it to anything
    in the second example you manually add MAINMAP1 to the stage (it now has a parent)
    so when you construct MAINMAP it removes itself from its parent
    to be honest I am suprised even the second one worked
    Apr 20, 2012 1:15 AM   in reply to thunderxlight11111
    either add MAINMAP1 using addChild in the constructor of your document class (if you have one)
    or you'll have to add it on the time line
    you should add an eventlistener in the constructor of MAINMAP
    addEventListener(Event.ADDED_TO_STAGE, onAdded);
    and then in your function onAdded you can access parent
    Apr 20, 2012 3:50 AM   in reply to thunderxlight11111
    onAdded get's called after addChild so what you have written makes no sense.
    if MAINMAP is you document class then you don't need to call addChild that will happen automatically
    Apr 20, 2012 4:57 AM   in reply to thunderxlight11111
    Sorry I don't understand what you are after
    Apr 20, 2012 5:00 AM   in reply to thunderxlight11111
    what you are trying to achieve
    Apr 20, 2012 5:42 AM   in reply to thunderxlight11111
    you can't
    you can never call MovieCli(parent).addChild(this) / as I am sure you understand now you don't have access to parent until after calling addChild()
    ok let's try and take this step by step
    do you have a document class? if so please paste it here
    Apr 20, 2012 5:45 AM   in reply to thunderxlight11111
    so you are adding you actionscript on the timeline?
    Apr 20, 2012 5:58 AM   in reply to thunderxlight11111
    Yes MAINMAP1 might be an external class, but you need to to either have a document class or add code the timeline as well
    Apr 20, 2012 6:22 AM   in reply to thunderxlight11111
    a class can't add itself to the display list. you have access to the display list from a document class or the timeline. you can then add any other objects to the display list including your MAINMAP1
