transfer of images
Apr 20, 2012 2:28 AM
I have upgraded from Lightroom 3.6 to Lightroom 4....but my images are are still in 3.6.....how do I transfer them across
    Apr 20, 2012 2:31 AM   in reply to kielder
    Open your Lr3 catalog in Lr4 and it will be upgraded. The reference to image files will be kept, of course.
    Apr 20, 2012 3:49 AM   in reply to Dorin Nicolaescu-Musteață
    Would this method work if you have lightroom version 4 installed on the same hard drive, will the Lightroom 3 catalogue remain unchanged.
    Regards
    Vividi
    Apr 20, 2012 4:01 AM   in reply to vividi
    LR4 will not change your LR3 catalog
    Apr 20, 2012 4:53 AM   in reply to dj_paige
    What about the new 2012 process in regards to the older processing of Lightroom 3.0 - 3.6
    do these remain the same or will every image be converted into the new 2012 processing
    algorithm upon conversion to Lightroom 4.0
    Regards
    Vividi
    Apr 20, 2012 4:57 AM   in reply to vividi
    When you convert your catalog from LR3 to LR4, all of the images in the new LR4 catalog remain in the old process (called "Process 2010") unless you specifically  change the photos to the new process ("Process 2012")
    Apr 20, 2012 5:56 AM   in reply to kielder
    kielder wrote:
    how do I do that
    How do you do what?
    Apr 20, 2012 6:18 AM   in reply to kielder
    One by one, go to Develop Module and click on the exclamation point that appears at the bottom right of the photo
    In bulk, change one photo to Process 2012 (as explained above) and then using the filmstrip select multiple additional photos (Ctrl-Click or Shift-Click) and hit Synchronize, then click on "Select None", then check Process Version and click OK.
    You might not want to do this in bulk, as the appearance of your photos usually changes when you convert to Process 2012. If you do it one by one, you can make sure that the appearance is what you want, or adjust it if it needs further adjustment.
