Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
Using attachment list as both input and output in UserServiceV2/AssignTask duplicates attachments
Avatar
Level 2
If I want to pass prior attachments to a user using v2 of  AssignTask I can pass in a list of documents (I'm calling it  attachmentList) in the Attachments tab. If I set Output Attachments to  the same variable, I get any new attachments the 2nd user may have  added, but the first user's attachments are now duplicated. If the  process is repeated, I'll have triplicates from user 1 and duplicates  from user 2.
What is the proper way to go about showing all  prior attachments to a new workspace user while allowing them to add to  the list, without this happening?
Avatar
Level 10
use the following XPATH expression in the output attach
ments variable
/process_data/attachmentsList[1]
This will prevent duplicating your existing attachments.
Avatar
Level 2
This solution is not working for me with LiveCycle ES3
Approver 1
Custom Container
Attachments Tab >
Input List :  attachList                                                [ datatype List <document> ]
Output attachments:   /process_data/attachList[1]         [ xpath expression ]
Approver 2
Custom Container
Attachments Tab :
Approver 3
Custom Container
Attachments Tab :
When approver 3 looks at the attachments any attachments added by Approver 1 are duplicated.
This duplication multiplies (eg approver 2 attachments duplicated and approver 1 attachments triplicated at Approver 4)  as the form is passed form task to task.
Any other settings I need to look at ?  Any other solutions out there ?
thanks
Avatar
Level 10
The configuration looks fine. In ES2 version, it works correctly. I do not know why this problem occurs in ES3.
Nith
Avatar
Level 2
thanks nith,
I will replicate the process in ES2 and check the results....
