Error #3200: Cannot perform operation on closed window.
Apr 20, 2012 1:37 AM
hi,
I'm simply trying to open a new window in a CS extension but when testing it inside Premiere as well as Illustrator it gives me the error
When I test it as a standalone desktop app, it works fine.
I tried it with an mxml Window component, and also with code, like:
var newWindow:Window = new Window()
newWindow.title = "New Window";
newWindow.width = 200;
newWindow.height = 200;
newWindow.open(true);
I'm using a WindowedApplication.
Flex 3.5
AIR  2.7
Flash Builder 4.5 (not using Extension Builder)
thanks!
Jeff.
    Apr 20, 2012 1:40 AM   in reply to JeffWinder
    You need to use CSXSInterface to open windows from within extensions. You cannot do it directly.
    Harbs
    Apr 20, 2012 7:10 AM   in reply to JeffWinder
    Sorry. I answered from memory. I remembered a little wrong. You basically had it, but you need to set the type.
    Here's how you do it:
    win:MyCustomWindowType = new MyCustomWindowType;
    win.showStatusBar = false;
    win.type = CSXSWindowType.MODAL_DIALOG;
    win.open();
    You probably want to create a component based on Window.
    Also, You should be using CSXSWindowedApplication. It could be that it's required for this...
