I have had a couple of documents that add blank pages no matter what you change the page count to....it drives me totally craxy. Close it and open it or make a pdf and get extra pages. It is only in the body section of the document. We have cover, toc, body, and then back cover. A co-worker is having the same problem with a document.
Page Count Set to Don't Change in book and document. I thought I had read about this somewhere but couldn't find it.
Is there an eaxy answer to correcting?
FM10
Windows XP
Thanks for any input!!
ls
Its probably because you are using default pagination, which makes the page count even before printing.
You also have to look at the following chapter to see if it's been set
to start on a left- or right-hand page. If, for example, chapter 1 is
three pages long, chapter 2 cannot start on page 4 if it's set to begin
on a right-hand page. So FrameMaker inserts a blank page 4 to make
chapter 2 start on a right-hand page (page 5).
From the book window, right-click on the file(s), select Pagination,
and set 1st Page Side to "Next Available." Note that this option is not
available when setting pagination from within a document window.
