prashant.savalia1
Rollover scrolling menu - no buttons
Feb 29, 2012 6:35 AM
Tags: #as3 #rollover #no_button #scrolling_menu
So below is my code for a project I'm working on. I'm having some trouble though. I got the code for the scrolling menus online from another forum, but I can't figure out where that was. In any case, the current version of the code allows for the scrolling to happen when I open the page displays (enter Frame). But I can't figure out how to get the scrolling to happen only when I hover over the menu. Can anyone help? I only want each one to scroll when I hover over the menu, not when I get on the page. I tried to replace the "enterFrame" part of the code, but it didn't work right. I need this done ASAP. Thanks in advanced!
import fl.transitions.Tween;
import fl.transitions.easing.*;
var mymovie = this;
var mymovieW = this.width;
var horizontalMode = 0;//1--horizontalMode; 0--verticalMode
var spaceImg = 7;//space beteen images
var fade = 0.5;
var containerPosition_x = 2;//put the container with images to the buttom of the stage
var containerPosition_y = 1;//put the container with images to the right of the stage
var yoffset = 10;//offset to adjust the position of big image on y axis
var xoffset = 10;
var numItems;
var objects;
var container:MovieClip = new MovieClip();
this.addChild(container);
var scrolling:Boolean = true;
var useFixedImageSize = 1;
var thumbnails:Array = new Array();
//load xml file
var xmlData = "Photoimages.xml";//set xml data file
var xmlObj:XMLDocument;
init();//init call -> load config XML and create objects
function init()
    xmlObj = new XMLDocument();
    xmlObj.ignoreWhite = true;
    var loader:URLLoader = new URLLoader();
    var request:URLRequest = new URLRequest(xmlData);
    loader.load(request);
    loader.addEventListener("complete", onComplete);
    loader.addEventListener("ioError", onIOError);
function onIOError(event:Event):void
    trace("IOERROR (maybe XML file does not exit or have an incorrect name)");
function onComplete(event:Event):void
    var loader:URLLoader = event.target as URLLoader;
    if (loader != null)
        xmlObj.parseXML(loader.data);
        xmlHandler();
    else
        trace("Loader is not a URLLoader!");
function xmlHandler()
    addObjects();
    startEngine();
function startEngine()
    container.addEventListener("enterFrame",startMovie);
function addObjects()
{//add objects in the scene
    objects = xmlObj.firstChild.childNodes;
    numItems = objects.length;
    for (var i=0; i<numItems; i++)
        var attr = objects[i].attributes;
        //Set the images
        thumbnails[i] = attr.thumb;
        init_thb(i);
function init_thb(i)
    if (useFixedImageSize == 1)
        var source1 = "AudioimgMc";//image mc linkage id from the library
    else
        source1 = "imgMc_01";
    var sourceType1 = "library";
    var regName1 = "p" + i;//the registration name used in Flash
    var classDef = getDefinitionByName(source1);
    var menuItemMc = new classDef  ;
    menuItemMc.name = regName1;
    container.addChild(menuItemMc);
    var myThumbMc = container.getChildByName(regName1);
    myThumbMc.buttonMode = true;
    myThumbMc.useHandCursor = true;
    myThumbMc.mouseChildren = false;
    myThumbMc["info"] = objects[i];
    myThumbMc.y = (myThumbMc.height+spaceImg)*(i);
    myThumbMc.x = (bkg.width-myThumbMc.width)/containerPosition_y;
    myThumbMc.alpha = fade;
    myThumbMc.addEventListener("mouseOver",mouseRollOver);
    myThumbMc.addEventListener("mouseOut",mouseRollOut);
    myThumbMc.addEventListener("mouseDown",mousePress);
function mouseRollOver(e:MouseEvent)
    e.target.alpha = 1;
function mouseRollOut(e:MouseEvent)
    e.target.alpha = fade;
function mousePress(e:MouseEvent)
    navigateToURL( new URLRequest( e.target["info"].attributes.url ), "_blank" );
function startMovie(e:Event)
    this.container.y += Math.cos((-stage.mouseY/stage.stageHeight)*Math.PI)*15;
        if (this.container.y > 0)
            this.container.y = 0;
        if (-this.container.y>(this.container.height-stage.stageHeight))
            this.container.y = -(this.container.height-stage.stageHeight);
    Feb 29, 2012 7:01 AM   in reply to prashant.savalia1
    Looks like it's starting to scroll on page launch and you say you only want that to happen if the user rolls over the item?
    What's starting the scrolling is this:
        addObjects();
        startEngine();
    It adds the objects, then starts the engine which adds the enterframe listener. You might want to adjust that to:
        addObjects();
        container.addEventListener(MouseEvent.MOUSE_OVER,startEngine,false,0, true);
    Then in the startEngine() function:
    function startEngine(e:MouseEvent)
        container.removeEventListener(MouseEvent.MOUSE_OVER,startEngine); // cleanup
    Mar 25, 2012 3:58 PM   in reply to prashant.savalia1
    Welcome
    Apr 19, 2012 11:33 AM   in reply to prashant.savalia1
    Sorry my time is short but beifly scanning, you cannot create a new "var source1" like you are trying. The linkage ID becomes a full "class".
    Thus your instantiation should look like:
    var source1:MovieClip = new PhotoimgMc();
    or
    var source1:MovieClip = new AnimationimgMc();
    or
    var source1:MovieClip = new AudioimgMc();
    If the "type" of the symbol differs (like to Sprite, etc) then change MovieClip to be whatever type it is.
    Apr 19, 2012 12:00 PM   in reply to prashant.savalia1
    Can you paste the relevant code on the frames that are erroring?
    And if you don't want MovieClips (which play by default) to play, then add an actionscript layer to them and add the stop() command in a frame script so they don't auto-play. You'll need to play() them once you're ready though.
    Apr 20, 2012 6:21 AM   in reply to prashant.savalia1
    There's a missing XML on that page that apparently has image names in them. All I'm getting is your IOError from your XML error handler.
    Apr 20, 2012 9:40 AM   in reply to prashant.savalia1
    At a quick glance it seems you're setting listeners over and over and over. Oddly in the 2 sliding image areas on left and right in services you remove an event listener so you know you can do that. But on the main frames you keep assigning the buttons (like Home, etc) over and over. This will result in adding a ton of listeners stacked up.
    I added the listeners once on the second frame and removed the assignment from then on. I also moved some of the redundant import statements to frame 1. As long as you import anything on frame1 in a timeline, the rest of the timeline can use it.
    The only errors I could see was due to you adding an onEnterFrame listener to those vertical sliding images but you never removed it. Once you go off the frame they kept firing off causing a spray of errors. I just adjusted it so on MOUSE_OUT it would remove the onEnterFrame and I don't get the errors anymore. I added a stopEngine() function that you can look at. I duplicated that for both of the sliders code.
    This is just the index saved down to CS4, I don't know what version you use:
    http://www.filehorde.com/o/Index_Fix_CS4.zip
    Consider centralizing the code to external AS files and then importing those. It's a huge PITA to go into someones project who has code sprinkled all over frames hidden in clips. Some of your code is 100% identical in separate clips so if you change anything (like I did) I had to change the frame scripts in both areas.. You're making it hard on yourself.
    Apr 21, 2012 7:19 PM   in reply to prashant.savalia1
    All that you dream of and more can be accomplished. Just not off agency time. Play with it and any methods used that you're unfamiliar with please read up on. Cya Monday
