How can I read xml file using web services?
Here is my cfc web services: (I just want to see how to read the xml file)
<cfcomponent>
<cffunction name="getBooks" access="remote" returntype="string" output="no">
<cfargument name="xmlObject" type="xml" required="yes" >
<cfset BookResponse = "">
<cfset var arrIndx = "">
<cftry>
<cfloop from="1" to="#ArrayLen(arguments.xmlObject.XmlChildren)#" index="arrIndx">
<cfset BookResponse= arguments.xmlObject.XmlChildren[arrIndx].XmlName>
</cfloop>
<cfcatch type="any">
<cfset BookResponse= "#cfcatch.message# #cfcatch.detail#">
</cfcatch>
</cftry>
<cfreturn BookResponse>
</cffunction>
</cfcomponent>
Here my code to test the web services:
1. Define the xml
<!--- Setup some XML to work with --->
<cfsavecontent variable="XMLFile"><?xml version="1.0"?>
<root>
<header>
<user>1</user>
</header>
<book>
<isbn>0321330110</isbn>
<title>Macromedia ColdFusion MX 7 Certified Developer Study Guide</title>
<author>Ben Forta</author>
</book>
<header>
<user>2</user>
</header>
<book>
<isbn>0596004206</isbn>
<title>Learning XML, Second Edition</title>
<author>Erik Ray</author>
</book>
<header>
<user>3</user>
</header>
<book>
<isbn>0782140297</isbn>
<title>Coldfusion MX Developer's Handbook</title>
<author>Raymond Camden</author>
</book>
</root>
</cfsavecontent>
2.Invoke the web services
<cfinvoke
method="getBooks"
returnvariable="rawXMLBookList"
webservice="http://localhost/Hoteleria/webServices/books.cfc?wsdl">
<cfinvokeargument name="xmlObject" value="#XMLFile#">
</cfinvoke>
<!---<cfset XMLDocResult = XmlParse(rawXMLBookList)>
<cfdump var="#XMLDocResult#">--->
<cfdump var="#rawXMLBookList#' >
3. Error: Element XMLOBJECT.XMLCHILDREN is undefined in ARGUMENTS.
I try also using XMLParse without luck.
Any ideas?
Sorry about that. It did work for me!
What about doing it on the basis of strings, as follows:
books.cfc
<cfcomponent>
<cffunction name="getAuthors" access="remote" returntype="string" output="yes">
<cfargument name="xmlString" type="string" required="yes" >
<cfset var xmlObject = "">
<cfset var rootChildren = "">
<cfset var authors = "">
<cfxml variable="xmlObject"><cfoutput>#arguments.xmlString#</cfoutput></cfxml>
<cfset rootChildren = xmlObje
...Copy link to clipboard
Looks like is not passing the XML doc.
I try this in my function: <cfset BookResponse = #xmlObject#>
Just to see if I can see the XML, I am getting this: [#document: null]
Any ideas?
Here is the solution:
http://www.bennadel.com/blog/1612-AxisFault-ColdFusion-Web-Services-And-XML-Data-Types.htm
Best,
There are few things you can improve, for example, using cfxml to pass an XML object, rather than cfsavecontent which passes a string. The following ilustrates this and other points:
books.cfc
<cfcomponent>
<cffunction name="getAuthors" access="remote" returntype="string" output="no">
<cftry>
<cfloop from="1" to="#ArrayLen(arguments.xmlObject.XmlRoot["root"].XmlChildren)#" index="arrIndx">
<!--- 'Author' elements are in 'book'. The 'book' elements are even-numbered --->
<cfif arrIndx mod 2 is 0>
<cfset authors = authors & chr(10) & chr(13) & arguments.xmlObject.XmlRoot["root"].XmlChildren[arrIndx].author.XmlText>
</cfif>
</cfloop>
<cfset authors = "#cfcatch.message# #cfcatch.detail#">
</cfcatch>
</cftry>
<cfreturn authors>
</cffunction>
</cfcomponent>
testPage.cfm
<cfxml variable="XMLFile"><root>
<header>
<user>1</user>
</header>
<book>
</book>
<header>
<user>2</user>
</header>
<book>
</book>
<header>
<user>3</user>
</header>
<book>
</book>
</root>
</cfxml>
<!---Invoke the web services--->
<cfinvoke
method="getAuthors"
returnvariable="authorList"
</cfinvoke>
<cfdump var="#authorList#" >
Thanks for you reply and help.
I try your suggestion, i got this error:
An error occured while Parsing an XML document. Content is not allowed in prolog.
If I change the function parameter type from xml to any, it pass but i get this error:
Element XMLOBJECT.XMLROOT is undefined in ARGUMENTS.
Any ideas?
How does your cfargument line look like?
I am using your example files. I have CF9.
Odd. Just as a test, what happens when you drop the arguments scope, like this
<cfloop from="1" to="#ArrayLen(xmlObject.XmlRoot["root"].XmlChildren)#" index="arrIndx">
<cfset authors = authors & chr(10) & chr(13) & xmlObject.XmlRoot["root"].XmlChildren[arrIndx].author.XmlText>
</cfif>
</cfloop
I am back to this XML issue.
I am getting this:
Element XMLROOT is undefined in XMLOBJECT.
Something is not clicking here.
Any ideas?
Thanks for your help!
books.cfc
<cfcomponent>
<cfset rootChildren = xmlObject.xmlRoot.xmlChildren>
<cftry>
<cfloop from="1" to="#ArrayLen(rootChildren)#" index="arrIndx">
<cfset authors = authors & chr(10) & chr(13) & rootChildren[arrIndx].author.XmlText>
</cfif>
</cfloop>
</cfcatch>
</cftry>
<cfreturn authors>
</cffunction>
</cfcomponent>
testPage.cfm
<!--- Setup XML string to work with --->
<cfsavecontent variable="XMLFile"><root>
<header>
<user>1</user>
</header>
<book>
</book>
<header>
<user>2</user>
</header>
<book>
</book>
<header>
<user>3</user>
</header>
<book>
</book>
</root>
</cfsavecontent>
<cfinvoke
method="getAuthors"
<cfinvokeargument name="xmlString" value="#XMLFile#">
</cfinvoke>
This solution work BKBK, Thanks!
Now if it is not much to ask. I add a general node at the top of the xml like:
<general>
<accountUser>234</accountUser>
</general>
How can I go to the node "accountUser", change the value and return the whole xml file with this new value updated?
Best,
<general>
</general>
<!--- The XML document object --->
<cfxml variable="XMLObject"><root>
<general>
</general>
<header>
<user>1</user>
</header>
<book>
</book>
<header>
<user>2</user>
</header>
<book>
</book>
<header>
<user>3</user>
</header>
<book>
</book>
</root>
</cfxml>
<cfset XMLObject.root.general.accountUser.xmlText = 567>
<cfdump var="#XMLObject#">
Thank you so much for your time and help!
Best,
How kind of you!
If the call to the web service continues to fail, then refresh the WSDL. The following code will refresh it:
<cfset serviceFactory = CreateObject("java", "coldfusion.server.ServiceFactory")>
<cfset rpcService = serviceFactory.XmlRpcService>
<cfset wsdl="http://localhost/Hoteleria/webServices/books.cfc?wsdl">
<cfset rpcService.refreshWebService(wsdl)>
Message was edited by: BKBK
