radio button javascript alert
Apr 20, 2012 6:05 AM
i am using the code below for form validations
var x=document.forms["form2"]["weeks"].value;
if (x==null || x=="")
  alert("Duration needs to be checked");
  return false;
but weeks is actually radio buttons
<input type="radio" value="364" name="weeks" />
<input type="radio" value="301" name="weeks" />
how do i convert the above code to work with a radio button
thanks
in advance
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Apr 20, 2012 6:23 AM   in reply to Jonathan Fortis
    <HTML>
    <HEAD>
    <SCRIPT LANGUAGE="JavaScript">
    function checkRadio (frmName, rbGroupName) {
    var radios = document[frmName].elements[rbGroupName];
    for (var i=0; i <radios.length; i++) {
    if (radios[i].checked) {
    return true;
    return false;
    function valFrm() {
    if (!checkRadio("frm1","weeks"))
    alert("You didnt select any weeks");
    else
    alert("You selected a week");
    </SCRIPT>
    </HEAD>
    <BODY>
    <FORM NAME="frm1" ACTION="javascript:valFrm();">
    <INPUT TYPE="radio" NAME="weeks" value="364"/>364
    <INPUT TYPE="radio" NAME="weeks" value="301"/> 301
    <INPUT TYPE="radio" NAME="weeks" value="400"/>400
    <INPUT TYPE="submit">
    </FORM>
    </BODY>
    </HTML>
    Try this script.
    Oct 15, 2010
    Apr 20, 2012 9:58 AM   in reply to Jonathan Fortis
    You seem to be wanting lot of validation in your code.
    Check out jQuery Validator plugin - http://bassistance.de/jquery-plugins/jquery-plugin-validation/
    It's a great lightweight plugin you could use for validating your form inputs.
    Oct 15, 2010
    Apr 20, 2012 11:03 AM   in reply to Jonathan Fortis
    They have Demos on their site that should give you complete insights.
    You could also download the source file kit here: http://jquery.bassistance.de/validate/jquery-validation-1.9.0.zip
    This kit includes demos, CSS, JS and all related files. They should help you get started.
    Oct 15, 2010
    Apr 20, 2012 11:08 AM   in reply to Jonathan Fortis
    For validating 2 radio buttons, try this:
    <html>
    <head>
    <script type="text/javascript">
    function validateRadio(obj,correct){
        var result = 0
        for(var i=0; i<obj.length; i++){
            if(obj[i].checked==true && obj[i].value==correct) result = 1
        if(!result && obj.value == correct) result = 1
        return result }
    </script>
    </head>
    <body>
    <form onSubmit="
    var err = ''
    if(!validateRadio(this.a,3)){ err+='\nFirst radio is wrong' }
    if(!validateRadio(this.b,2)){ err+='\nSecond radio is wrong' }
    if(err.length){ alert('Problem:'+err); return false; }
    else{ alert('Good Job -- Submitting'); return true; }
    action="#">
      Choose "3"
      <input name="a" value="1" onChange="if(!validateRadio(this,3)) alert('Incorrect')" type="radio">
      1
      <input name="a" value="2" onChange="if(!validateRadio(this,3)) alert('Incorrect')" type="radio">
      2
      <input name="a" value="3" onChange="if(!validateRadio(this,3)) alert('Incorrect')" type="radio">
      3
      <input name="a" value="4" onChange="if(!validateRadio(this,3)) alert('Incorrect')" type="radio">
      4
      <p>Choose "2"
        <input name="b" value="1" type="radio">
        1
        <input name="b" value="2" type="radio">
        2
        <input name="b" value="3" type="radio">
        3
        <input name="b" value="4" type="radio">
        4 </p>
      <p>
        <input value="Submit" type="submit">
      </p>
    </form>
    </body></html>
    Oct 15, 2010
    Apr 20, 2012 11:41 AM   in reply to Jonathan Fortis
    Try this for 2 validations:
    <HTML>
    <HEAD>
       return true;
    return false;
    function valFrm() {
    if (!checkRadio("frm1","start"))
      alert("You didnt select any start week");
    else
      alert("You selected a start week");
      if (!checkRadio("frm1","end"))
      alert("You didnt select any end week");
      else
      alert("You selected a end week");
    </SCRIPT>
    </HEAD>
    <BODY>
    START
    <INPUT TYPE="radio" NAME="start" value="364"/>364
    <INPUT TYPE="radio" NAME="start" value="301"/> 301
    <INPUT TYPE="radio" NAME="start" value="400"/>400
    <br>
    END
    <INPUT TYPE="radio" NAME="end" value="400"/>100
    <INPUT TYPE="radio" NAME="end" value="400"/>200
    <INPUT TYPE="radio" NAME="end" value="400"/>300
    <BR>
    </FORM>
    </BODY>
    </HTML>
    Oct 15, 2010
    Apr 20, 2012 11:44 AM   in reply to Sudarshan Thiagarajan
    For Title, append this script in your function:
    function valFrm() {
    else
      else
      if (!checkRadio("frm1","title"))
      alert("Title needs to be selected");
      else
      alert("You selected a title");
    Oct 15, 2010
    Apr 20, 2012 11:46 AM   in reply to Sudarshan Thiagarajan
    Also, if you don't want alert messages for boxes that are already validated 'true', you could simply use 'else if' instead of 'if' in the function
    Oct 15, 2010
    Apr 20, 2012 11:57 AM   in reply to Jonathan Fortis
    Replace all if from 2nd if onwards with else if
    It should work
    Oct 15, 2010
    Apr 20, 2012 9:09 PM   in reply to Jonathan Fortis
    Post your latest code
