Application icons
Feb 9, 2012 1:36 AM
    Mar 26, 2012 1:03 AM   in reply to Community Help
    It differs a little from what you wrote here. For example, now it says in the documentation:
    "For Spotlight search results on iPad, create two icons that measure:50 x 50 pixels", and than "Note that the final visual size of a Spotlight search results icon on iPad is 48 x 48 pixels"
    So shouldn't it be   ?
    Could you clarify it?
    Mar 26, 2012 1:06 AM   in reply to drunk.cat
    I meant:
    So shouldn't it be in the xml: image50x50 rather than image48x48 ?
    Apr 20, 2012 2:19 PM   in reply to Community Help
    There is an error that is thrown when you try to remove the gloss / shine from the icon, this is the code I have:
    Once I try to compile the app on the mobile device, I get an error:
    Error occurred while packaging the application:
    /private/var/folders/zn/znI7EuqSEoGgRID9pjCm-E+++TI/-Tmp-/AOT133495665 1018/someApp-app.xml(238): error 103: application.iPhone is an unexpected element/attribute
    Apr 20, 2012 2:20 PM   in reply to Yozef0
    don't know why the code dosen't show (try #2 - basically the same as the one indicated above):
    Apr 20, 2012 9:59 PM   in reply to Yozef0
    Can you check if you have 2 iPhone tags in your app desciptor?
    Apr 21, 2012 5:56 AM   in reply to neh@adobe
    You are 100% right , there was another tag after scrolling down. My bad.   Thanks guys :)
    Oct 5, 2012 10:13 AM   in reply to Community Help
    Is there an Android equivalent to the "Launch Image" on iOS. The one that appears as the app is initializing. On Android, I just get a black screen while it loads.
    Nov 6, 2012 9:02 PM   in reply to Community Help
    This document fails to clarify that if you already have an InfoAdditions node, you do not have to add a new one.
    The code provided by Adobe to remove the gloss effect must go inside the existing node, before the UIDeviceFamily.
    This is what worked for me:
    <InfoAdditions><![CDATA[<key>UIPrerenderedIcon</key><true/><key>UIDevi ceFamily</key><array><string>2</string></array>]]></InfoAdditions>
    Feb 13, 2013 10:16 PM   in reply to Community Help
    Please add support for xhdpi icon for android i.e. 96x96. It's now long over-due.
    Feb 26, 2013 8:40 PM   in reply to Community Help
    No matter what, no matter where I put them, Default png launch images NEVER WORK.
    Am I supposed to include them under the AIR for iOS settings? (I use Flash Professional CS6)
    Feb 26, 2013 8:47 PM   in reply to art_guy
    Yes. you need to include them in the "AIR for iOS settings > General tab> Included Files" section. Then, they should work.
    May 7, 2013 5:10 AM   in reply to askSaGe
    96x96 is added with AIR 3.7
    Jun 12, 2013 12:19 AM   in reply to pierBover
    This doc fails in one more thing, in Flash CS6 you CANNOT edit the .xml before Publish, so you need to unpackage the .ipa with Air SDK command line, edit the .xml and package again the .ipa with the command line and signing again the .ipa (otherwise it won't be recognized by the iOS devices!!!!!)
    Why Adobe, WHY!!??
    Jun 12, 2013 12:21 AM   in reply to cocoua
    it's as easy as a checkbox on the Publish settings!!!!
