Is it just me ? It appears my project files keep going south.
Apr 20, 2012 1:20 PM
Been working on a project, about an hour of footage, two cameras, Canon HF20 and Canon T3i. Seperate audio, 48K 16bit
In addition to the footage I also have,
PSD's(8), JPG's(2) and After Effects Comps(6), mainly just clips with Warp Stabiliser.
There are many edits. 80% is single track but the other 20% ranges from 2 track comps to 4 tracks.
This is what I am seeing.
I started the project, worked on it for about 3 hours, 95% done. Saving regularly. Then I closed it and went off to do something else.
Came back and opened the project. Then I noticed the preview window stayed white. I tried a preview but nothing, the audio plays and the shuttle moves but the preview window stays white.
Then I noticed that the CPU remains at 25% (Have a quad core so I assume it is running 1 core). Left it for about 5 minutes, no change, CPU stays 25%. Nothing else but Premiere running. Looked in task manager, premiere pro 25% when nothing is happening in premiere pro.
So I tried to close the project. Then Premiere Pro just hangs. Left it for 3 minutes, nothing. So I killed it by shooting it in task manger.
Tried it 3 times, same story. Tried rebooting, same story.
Finally I started a new project and imported the troubled project into that. Worked like a champ, previerw window previews as expected and all is great.
Well, this seems to happen each time I close the project, then I have to start a new project and import the old one, except my luck just ran out. Luckily I am finished and busy with the render but dread having to go back and make any touch-ups, since the import trick doesn't appear to work anymore.
Is this a known issue ? Am I doing sometihng wrong ? Is there a feasible workaround ?
Art
    Apr 20, 2012 3:28 PM   in reply to deimosphobos
    More information needed for someone to help... click these links and provided the requested information
    -http://forums.adobe.com/message/4200840
    -http://forums.adobe.com/thread/416679
    Also, for pictures...
    Photo Scaling for Video http://forums.adobe.com/thread/450798
    -Too Large May = Crash http://forums.adobe.com/thread/879967
    -And another crash report http://forums.adobe.com/thread/973935
  • joe bloe premiere
    Dec 6, 2009
    Apr 20, 2012 3:31 PM   in reply to deimosphobos
    Not really...Maybe... And you shouldn't need to work around this uncommon problem.
    A bit of system information (especially your video card and driver version) would be useful.
    Apr 21, 2012 10:02 AM   in reply to deimosphobos
    The white preview window speaks to a video driver issue.  You might look at that for a solution.
    Apr 21, 2012 10:14 AM   in reply to deimosphobos
    In addition to the above questions, I think these should be SOP before you post to any forum for help:
    Have you deleted your preferences?   (opt/alt held down while launching Premiere Pro)
    Have you eliminated source file corruption as your problem?  (tried a new project with entirely different footage)
    These are the two most common sources of issues on my system (and many others), and that's been the case for all the NLEs I've worked with (MC, FCP, Pr), and Ae, for about twenty years.
