EDMLLC
Project Setting - Transcoding Settings question
Apr 20, 2012 11:35 AM
Hello all,
I am a bit confused on the Encore settings.    Should I leave them as the default or should I tweak them??    The DVD tests that I have made seem to have a little bit of interlacing during playback in the Sony player that I am using via HDMI to the Sony TV.
When I check "project settings" in Encore it shows:  Transcode Settings:   Codec MPEG 2, 720x480 Frame Rate 29.97  (my project is 23.976fps)
        Fields : Lower Field First
When I check "edit quality presets"   It shows  Export Settings -  MPEG2 Blu-ray,    1280x720p  23.976
        Summary:
        Output:           1280x720 23.976  De-interlaced
        Source           1920 x 1080  23.98,  Lower
        Basic Video Settings:
        1280x720,  23.976
        Field Order  None(progressive)
I guess It just seem like there is conflicing info with the Fields and with the Frame Rate.
Is this the way it is supposed to be or do I need to customize the settings?
Thank you in advance for being nice.
    Apr 20, 2012 4:27 PM   in reply to EDMLLC
    Is this a DVD or Bluray?
    Apr 20, 2012 8:17 PM   in reply to EDMLLC
    There are 2 sets of "edit quality" presets: DVD and Bluray. Be sure you are setting the ones for DVD. Also be sure you are lookng at the DVD Transcode Status columns in the Project Panel, and not the ones further to the right for Bluray.
    For DVD, you will be using MPEG2-DVD. There are many issues in setting the rates manually.
    You might also try settingh the DVD Transcode settings to Automatic.
    May 2, 2012 3:07 PM   in reply to EDMLLC
    If you want to avoid field issues, export from Premiere to mpeg2-dvd and import into Encore.
    This way Encore will not re-encode and you can ignore the lower fiels message.
