#Shareobjects deleting itself
Apr 14, 2012 6:25 PM
Tags: #problem #help #issue #update #firefox #flash_player_11
Windows Vista 64bit
Firefox 11
Flash Player is up to date - 11.2.202.228
The file #sharedobjects keeps emptying itself causing all saved data in game and such to be wiped. I'm not sure on what time frame it auto-deletes but this happened after the latest flash player update.
  • Chris Campbell
    May 4, 2010
    Apr 20, 2012 5:23 PM   in reply to Sandalman3000
    Do you have anything running that could be cleaning your browser's cache?  Do you have the Firefox extension BetterPrivacy installed?
    Apr 21, 2012 7:05 PM   in reply to Sandalman3000
    Do you run any cleaning tools such as CCleaner?  If so, you may want to turn off Flash Player cleaning.
    Apr 22, 2012 6:34 PM   in reply to Sandalman3000
    Sorry, I have no more ideas; hopefully someone from the Flash Player team can come up with additional ideas.
    All I can say is that Flash Player does not do that by itself, so it must be something else.  Norton/Symantec of course are always suspects.
  • Chris Campbell
    May 4, 2010
    May 2, 2012 5:22 PM   in reply to Pat Willener
    First, just for sanity sake, you aren't using private browsing are you?
    If not, the next thing I'd try is to see what is writing and deleting files from your #SharedObjects folder.  Grab Process Monitor and start it up.  Create a new filter with:
    "Path", "begins with", "C:\Users\username\AppData\Roaming\Macromedia\Flash Player\#SharedObjects", "include"
    From here you might be able to see what process is deleting the file.  You can also add another filter with "detail" "contains" "delete" "include".
    Finally, if you haven't already you might want to consider resetting your Firefox profile.
    Make a new profile
    Chris
    May 2, 2012 7:26 PM   in reply to Sandalman3000
    Can you see any activity?  You should see who/what does any activity in there.
  • Chris Campbell
    May 4, 2010
    May 4, 2012 5:16 PM   in reply to Sandalman3000
    I'd look for the word "delete" in the detail column.  Hopefully you see when one of these files/folders are being deleted and you can see what process is responsible.
  • Chris Campbell
    May 4, 2010
    May 11, 2012 4:24 PM   in reply to Sandalman3000
    I believe this started in 10.3.
