In the list of available fonts, Illustrator CS5 just doesn't show a particular bitmap font (maybe it's skipping some others too, but I didn't check). I'm sure the font works well, in fact it shows up and works normally in Photoshop, and I also use it for interface in some other software that allows customizing of interface - in a few years never had a problem. If it matters, it's a fon file.
Digging around the internet I didn't see anybody complaining about it, the only thing I've found is an article for beginners that talks about using bitmap fonts as if it were perfectly possible.
So, how can I use this font in my documents? Or will I have to design everything in Illustrator and then finish it in Photoshop.
Edit: if it matters I'm on Windows 7 64bit.
Message was edited by: RayRayTea
That's true, but what made me think Illustrator should be able to read a puny bitmap font is (among other things) this piece - I wouldn't trust it too much ("Pixel fonts are quite popular these days. It all started in Flash…") but it actually has screenshots, so I assumed they must have materialized from somewhere (and what it says about positioning of the lines is true, so it probably knows what it's talking about).
Edit: and I just noticed… the fonts I actually have as "Hidden" (in the Font control panel) show up in Illustrator all right - Comic Sans says hello (I should have uninstalled it instead of hiding it I guess). Heh…
RayRayTea,
It seems that it should be possible, as briefly mentioned here:
http://www.scribd.com/doc/88426164/245/Understanding-bitmap-fonts
So it seems that Wikipedia has it wrong(ly expressed).
Maybe the fonts you have tried are simply beneath the standard required by Illy; she is more particular than most, which is understandable because she may have to do a lot of things with fonts, as vector artwork.
