Everytime I open Adobe Digital Editions for my PC it says "Could Not Find Digital Editions Folder.
Apr 21, 2012 9:01 AM
Tags: #adobe_digital_editions
It won't let me download any books. Im currently using a online book reviewing service and it says to download the books onto this program. The book files goes into my computer files but it wont go into this program itself. Help??
    Apr 21, 2012 10:21 AM   in reply to dldsnjdjhfdfdsjbdfsjdfsh
    Digital Editions keeps track of where the library is located in the
    'Manifest.xml' file.  If you used a utility program to move the Digital
    Editions library, then the Manifest.xml file will not have the correct
    location of the library and would give you this error.
    Don't mess with the Zohan.
    On Sat, Apr 21, 2012 at 9:01 AM, dldsnjdjhfdfdsjbdfsjdfsh
    Apr 21, 2012 3:34 PM   in reply to dldsnjdjhfdfdsjbdfsjdfsh
    There's about a million things that you could tell us to help make your
    situation clearer, and thus the answer less confusing.  You' can tell us
    what you did, what kind of PC you're working on (whether it runs Windows 7
    or Windows something-else) and how you downloaded and installed ADE.  You
    can tell us why you think that ADE should help you download ebooks.  And
    you can tell us what site you're working with.  Anything more than you've
    said so far that helps to clarify what you meant in your post will help us
    be less confused - and help you to that goal as well.
    On Sat, Apr 21, 2012 at 1:27 PM, dldsnjdjhfdfdsjbdfsjdfsh
    Apr 22, 2012 10:08 AM   in reply to dldsnjdjhfdfdsjbdfsjdfsh
    "this site" - ?
    The normal process would be to register with Adobe, then download ADE,
    which would install directly from the Adobe website.  If you didn't
    register, and/or downloaded ADE from somewhere else, then that might not
    work.  When ADE downloads, it installs itself, AND establishes the links to
    its folders, so I suspect now that something went wrong during the
    installation, rather than some issues that you might have caused using
    utility programs.
    Vista is not a 'robust' operating system, and it's also possible that Vista
    'hiccuped' during the ADE install and screwed up the registry entries.
    If you registered with Adobe and then downloaded ADE, we can check a couple
    of settings to see what's up.
    On Sat, Apr 21, 2012 at 8:14 PM, dldsnjdjhfdfdsjbdfsjdfsh
