Hi all
I am new to the Adobe arena so I hope that some one can please lead me to accomplish this task.
I have 2 text fields last name & first name
I would like to have it create a third field with the last name, (first character of the first name field) and placing a comma after the last name.
Thank you
James
Total Likes
You would place the script in the calculate event of the third field.
This should get you close (you will need to change the object references to suit the names of your objects):
I will use JavaScript:
if (lastName.rawValue !== null && firstName.rawValue !== null) {
this.rawValue = lastName.rawValue + ", " + firstName.rawValue.toString().slice(0,1);
You may not need the .toString() bit, but give it a try.
Niall
Total Likes
Hi Niall,
I placed your script into the custom calculation script and rename my
fields to match what is in the script however for some reason in the new
field nothing came out. All fields are text.
Any idea?
James
Total Likes
Sounds like you are designing your form in Acrobat and NOT LC Designer. Is that correct?
AcroForms use a slightly different syntax (closer to Core JavaScript).
Niall
Total Likes
Hi Niall, I was using the form editor, is there a difference, I am using
Adobe X Pro.
James
Total Likes
Hi James,
Yes, it does. LC Designer creates different forms and has different JavaScript syntax. You are in the LC Designer forum and your query may be better answered in an Acrobat forum.
The following script should work in an AcroForm (fingers crossed):
var i = this.getField("firstName");
var j = this.getField("lastName");
var k = this.getField("combinedName");
if (i.value !== null && j.value !== null) {
k.value = j.value + ", " + i.value.toString().slice(0,1);
As before, you will need to change the object references to suit your form.
Hope that helps,
Niall
Total Likes
I revised Niall's script some to make it work as a custom calculation script and make it a bit more suitable for an Acroform:
// Get the field values, as strings
var i = this.getField("firstName").valueAsString;
var j = this.getField("lastName").valueAsString;
// Set this field's value if both fields are not blank
// otherwise, set this field to blank
if (i && j) {
event.value = j + ", " + i.slice(0, 1);
} else {
event.value = "";
(An acroform field value will never be equal to null.)
Total Likes
Thanks George!
Total Likes
Hi All,
I do not know what is going on however, still nothing comes up....
Total Likes
The code posted assumes your fields are named "firstName" and"lastName". If your fields are named something else, you'll have to use the exact field names. You can also check for errors in the JavaScript console (Ctrl+j). It is written to be a custom calculate script, so make sure it's in the right place. It will get triggered whenever any field value changes.
Total Likes
