I am hoping someone can help with this. I am trying to take a Base64 string that is passed from a web form and, using ColdFusion (Version 6) conver that to a JPG image that can be posted to the server and a reference stored in a database.
I have the string being passed and it seems to be converting (at least it's creating a jpg file) but when I go to view the file, it's empty. If I view it in Preview on a Mac it says: "It may be damaged or use a file format that Preview doesn’t recognize."
Here is what I am using:
<head>
<cfif isdefined("form.imageName")>
<cfset newJPG = form.imageName>
<cffile action="write" file="#expandPath("images/newimage.jpg")#" variable="newJPG" output="#newJPG#" addnewline="no">
</cfif>
</head>
<body>
<cfoutput>
The string as an output <br /><br />
#newJPG#<br /><br />
The image as written back to a file<br /><br /><img src="#expandPath("images/newimage.jpg")#" /></cfoutput>
</body>
What am I doing wrong?
There are some subjects to touch upon: tobase64(), toBinary(), and so on. An example will illustrate it best.
My current directory contains the picture penguins.jpg. I have also created a new directory, image, within the current directory. My suggestion follows:
<cfif isDefined("form.image_in_base64")>
<cfset base64JPG = form.image_in_base64>
<cfset binaryJPG = toBinary(base64JPG)>
<cffile action="write" file="#expandPath("images/newimage.jpg")#" variable="newJPG" output="#binaryJPG#" addnewline="no">
<cfoutput>
#base64JPG#<br /><br />
</cfoutput>
<cfelse>
<cffile action="readbinary" file="#expandPath('penguins.jpg')#" variable="binaryImg">
<cfset base64Img = tobase64(binaryImg)>
<cfform>
<cfinput name="image_in_base64" type="text" value="#base64Img#">
<cfinput name="sbmt" type="submit" value="Send">
</cfform>
</cfif>
Thank you! That is what I was missing. The image is still not displaying in the output:
<cfoutput>
</cfoutput>
But it is writing the file.
Oh right. Just staring at it too long I guess.
Now I have another string. It's a string from a Canvas element. The canvas grabs a signature. I should be able to convert that the same way correct? First I convert it to a base64 string and then to a jpg. It's writing the file again, but I get the same error saying the file is corrupt. Here is how ai am writing this one:
The field with the signature string is called "output"
<!-- Signature Processing -->
<cfset thisString = "#form.output#">
<cfif isdefined("form.output")>
<cfset sig_in_Base64 = toBase64(thisString)>
<cfset sigbase64JPG = sig_in_base64>
<cfset binarySigJPG = toBinary(sigbase64JPG)>
<cffile action="write" file="#expandPath("images/signatures/#form.vin#_Signature.png")#" variable="newSigJPG" output="#binarySigJPG#" addnewline="no" nameconflict="overwrite">
</cfif>
Should this work the same way?
It is gathered from an HTML Canvas element in a form (along with some javascript):
<form>
<div class="sigPad">
<ul class="sigNav">
<li class="drawIt"><a href="#draw-it" >Your Signature</a></li>
<li class="clearButton"><a href="#clear">Clear</a></li>
</ul>
<div class="sig sigWrapper">
<div class="typed"></div>
<canvas class="pad" width="420" height="55"></canvas>
<input type="hidden" name="output" class="output">
</div>
</div>
<input type="submit" value="Submit Form" id="submit" class="button">
<input type="reset" value="Reset Form" class="button" />
</form>
when they submit the form, the value transferred is formatted:
[{"lx":19,"ly":28,"mx":19,"my":27},{"lx":21,"ly":27,"mx":19,"my":28}, {"lx":25,"ly":27,"mx":21,"my":27},{"lx":30,"ly":27, .......
That is the string that I am trying to convert to the jpg (or png). As an answer to the other question, it does not seem to matter png or jpg. This is where I have it now and I am still receiving the same result:
<cffile action="write" file="#expandPath("images/signatures/#form.vin#_Signature.jpg")#" variable="newSigJPG" output="#binarySigJPG#" addnewline="no" nameconflict="overwrite">
</cfif>
Maybe it is not possible to translate it this way? Am I thinking about it the wrong way?
Gregory Nelson wrote:
That's in the Javascript that is writing the JSON representation of the signature to the hidden field named "output." I am then passing that JSON representation to the server to be processed. Does that make sense?
It does indeed make sense. However, I don't think we can convert from JSON to images as we did above.
Nihilogic.dk does Javascript conversions from Canvas to image types. He uses a library consisting of Canvas2Image.js and base64.js. The key function is toDataURL(), which converts a Canvas to the base64 representation of a JPG or PNG file.
