Base64 string to JPG
Apr 15, 2012 5:31 PM
I am hoping someone can help with this. I am trying to take a Base64 string that is passed from a web form and, using ColdFusion (Version 6) conver that to a JPG image that can be posted to the server and a reference stored in a database.
I have the string being passed and it seems to be converting (at least it's creating a jpg file) but when I go to view the file, it's empty. If I view it in Preview on a Mac it says: "It may be damaged or use a file format that Preview doesn’t recognize."
Here is what I am using:
<head>
<cfif isdefined("form.imageName")>
<cfset newJPG = form.imageName>
<cffile action="write" file="#expandPath("images/newimage.jpg")#" variable="newJPG" output="#newJPG#" addnewline="no">
</cfif>
</head>
<body>
<cfoutput>
The string as an output <br /><br />
#newJPG#<br /><br />
The image as written back to a file<br /><br /><img src="#expandPath("images/newimage.jpg")#" /></cfoutput>
</body>
What am I doing wrong?
    Apr 16, 2012 12:41 AM   in reply to Gregory Nelson
    There are some subjects to touch upon: tobase64(), toBinary(), and so on. An example will illustrate it best.
    My current directory contains the picture penguins.jpg. I have also created a new directory, image, within the current directory. My suggestion follows:
    <cfif isDefined("form.image_in_base64")>
        <cfset base64JPG = form.image_in_base64>
        <cfset binaryJPG = toBinary(base64JPG)>
        <cffile action="write" file="#expandPath("images/newimage.jpg")#" variable="newJPG" output="#binaryJPG#" addnewline="no">
        <cfoutput>
        #base64JPG#<br /><br />
        </cfoutput>
    <cfelse>
        <cffile action="readbinary" file="#expandPath('penguins.jpg')#" variable="binaryImg">
        <cfset base64Img = tobase64(binaryImg)>
        <cfform>
            <cfinput name="image_in_base64" type="text" value="#base64Img#">
            <cfinput name="sbmt" type="submit" value="Send">
        </cfform>
    </cfif>
    Apr 18, 2012 12:16 AM   in reply to Gregory Nelson
    Gregory Nelson wrote:
    But it is writing the file.
    And this: <img src="images/newimage.jpg">?
    Apr 21, 2012 12:52 PM   in reply to Gregory Nelson
    Could it simply be corrected by reversing the typing mistake? That is,
    <cfif isdefined("form.output")>
    <cfset thisString = "#form.output#">
    instead of
    Apr 22, 2012 12:34 AM   in reply to Gregory Nelson
    How does the string form.output begin? Could you show us the first lines of the output? Also, could it be that you intended to write to _Signature.jpg in the cffile rather than to _Signature.png?
    Apr 22, 2012 6:56 AM   in reply to Gregory Nelson
    It isn't clear from this code how the canvas gets into the form as a string. The following 2 elements apparently have nothing to do with each other:
    <canvas class="pad" width="420" height="55"></canvas>
    <input type="hidden" name="output" class="output">
    Apr 22, 2012 8:05 AM   in reply to Gregory Nelson
    That's in the Javascript that is writing the JSON representation of the signature to the hidden field named "output." I am then passing that JSON representation to the server to be processed. Does that make sense?
    It does indeed make sense. However, I don't think we can convert from JSON to images as we did above.
    Apr 22, 2012 9:43 AM   in reply to Gregory Nelson
    Having a look.
    Apr 23, 2012 12:03 AM   in reply to Gregory Nelson
    Nihilogic.dk does Javascript conversions from Canvas to image types. He uses a library consisting of Canvas2Image.js and base64.js. The key function is toDataURL(), which converts a Canvas to the base64 representation of a JPG or PNG file.
