Resize Text Bounding Box
Aug 19, 2011 12:36 PM
Exactly how does one change the size of the text bounding box, without scaling the text or changing the font size?
I have a method now, but it is very inconvenient. I am looking for something to improve workflow.
    Aug 19, 2011 12:40 PM   in reply to Brian2025
    Which version of Illustrator are you using? What's your current method?
    Aug 19, 2011 12:57 PM   in reply to Brian2025
    Sounds like you're going to use numeric input.
    Go to the menu Type > Area Type options
    Aug 19, 2011 2:10 PM   in reply to Brian2025
    That self-evident command you're looking for has not been there in Illustrator for about 25 years.
    You could write a script or you could use one of them that have already been written. But don't be too surprised to explore their stumbling blocks.
    Aug 19, 2011 2:20 PM   in reply to Brian2025
    You might explore making a graphic style which adds a new fill with relative extents which could be applied to the text boxes. The only problem I had with this is that it turns the character level fill blank and has to be reapplied. I've also just used the eyedropper to transfer the same kinds of settings from one block of styled text to many others which doesn't require reapplying the base character fill.
    Mar 15, 2012 11:01 AM   in reply to Kurt Gold
    That's a stupid reply. I could resize a text box by dragging its handles in CS3, just a few years ago. Now it doesn't behave that way. Though why Adobe would force users to enter text box dimensions in a modal dialog box instead of intuitively grabbing a box handle and stretching is beyond me. Obviously there must be a tool that does this without modifying the text itself.
    Mar 15, 2012 11:55 AM   in reply to grtgrfx
    Works fine here with SC5. Scaling and rotating a text box with the selection tool (black arrow) doesn't affect the text, just the box. Make sure it is a text box and not just text.
    Mar 17, 2012 4:04 AM   in reply to Brian2025
    Turn off bounding boxes when working with text.
    Use Direct Selection tool to drag text box edges.
    Or Direct Select text box ony with Option held down (to select the whole box), then use Scale tool.
    Just be careful to select the text box only, not the type. Turning off the preview can make this easier.
    Mar 17, 2012 5:00 AM   in reply to Brian2025
    Brian,
    You may consider this option:
    http://forums.adobe.com/message/3604219#3604219
    You can read the rest of the thread for further considerations.
    Apr 21, 2012 10:58 AM   in reply to Brian2025
    Brian,
    If you didn't figure it out yet... go to View and click Show bounding box.
    The bounding box shows the editable outline of the text object trying to enlarge or scale.
    its a simple case of not having the right view option turned on.
    now you can use the selection tool (black arrow) to drag any corner point of your text bounding box.
    easier than inputting numbers all day long.
    Apr 21, 2012 2:48 PM   in reply to iamcougar
    No. This is complete disinformation.
    Using a bounding box will scale/distort the type.
    Instead, direct select the text box as per post #11.
    The OP specifically said that he did not want to scale the type.
    Apr 21, 2012 3:10 PM   in reply to Brian2025
    Sorry Steve,
    Not sure what settings you have set in your illustrator prefs, but i'm rockin cs5.1 and for me showing the bounding box enables me to grab the corner handles of the text box with the selection tool (black arrow). and... this does NOT scale the type, it just opends the box up so you can see the rest of the words you are typing.
    Here are some screens showing bounding box ON. and the 2nd showing the selection tool resizing the text box without scaling.
    Aug 8, 2012 1:11 AM   in reply to iamcougar
    Yes, Bounding box ON, and then is possible to resize the text box with selection tool.
    The text isn't scaled.
    Thanks a lot
    Oct 4, 2012 2:02 PM   in reply to deivisali
    I think there's still some misunderstanding. What you're experiencing is the difference between "point type"(text scales w/ the bounding box) and "area type" (text does not scale with the bounding box). Point type and area type have slightly different bounding boxes.
    See  http://rwillustrator.blogspot.com/2007/08/technique-scaling-area-text. html
    Mar 11, 2013 6:32 AM   in reply to Jens650
    Is it possible to get the bounding box to shrink to the edges of the type, without changing its size? So that I can center the type over an object more easily?
    I find it really frustrating that I'll be working on a word, like on a logo, and the box will be wider than the type. Then, of course, if I use any of the alignment buttons to align the text to an object, the alignment is wrong. I've never found a way to shrink the box to the size of the type...
    Apr 27, 2013 8:51 AM   in reply to Brian2025
    Using Type > Area Type Options works for me. I can turn on the preview mode and adjust the width without changing the type size.
