xmasgame
[AS2] Character movement
Apr 21, 2012 12:55 PM
Okey my character got this script: (its lots more but yeah.. this is the trouble code).
Frame 1 = character stand still
Frame 2 = character (MC) - movement
Frame 3 = character (MC) - Jump movement
It works fine, when I press UP, he jumpes and play frame 3.
When i press left and right it plays frame 2.
When I press .. nothing, frame 1 is played.
That correct!
BUT when i press .. left + up, or right + up, it will play frame 1.
Any idea how i can make it play Frame 3 (jump) even if I press two buttons at the same time? Would be awesome if someone knew it.
onClipEvent (enterFrame) {
if (Key.isDown(Key.RIGHT)) {
_root.player.gotoAndStop(2);
if (Key.isDown(Key.LEFT)) {
if (Key.isDown(Key.UP)) {
_root.player.gotoAndStop(3);
if (!Key.isDown(Key.LEFT) and (!Key.isDown(Key.RIGHT) and (!Key.isDown(Key.UP)))) {
this.gotoAndStop(1);
    Apr 21, 2012 2:17 PM   in reply to xmasgame
               do something
                        } else if (Key.isDown(Key.RIGHT)) {
                do something
              } else {
                        } else if (Key.isDown(Key.LEFT)) {
                        } else {
    This should solve that. but I can't guarantee if it will cause any problem for your game.
    Apr 21, 2012 5:00 PM   in reply to xmasgame
    Just use the and opperator: &&
    so something like:
    if (Key.isDown(Key.LEFT) && Key.isDown(Key.UP) ) {
    if (Key.isDown(Key.RIGHT) && Key.isDown(Key.UP) ) {
    Apr 21, 2012 7:41 PM   in reply to xmasgame
    the do something is not surpose to be in the code, it means the place for you to add your actions inside. like setting a different movement speed where it's nested without having to assign the jumping again.  prodigal master's code will work as well. depending on what way you want to script it.
    Apr 22, 2012 4:57 AM   in reply to xmasgame
    Maybe that is because it is repeatedly goto and stopping on frame (3) due to the key's being down. Maybe use a boolean variable e.g. isJumping = false; and when the jump animationbegins make it isJumping = true; and finally when the animation ends make isJumping = false; and therefore in the code use && in the if statement with isJumping == false
    Apr 22, 2012 8:59 AM   in reply to xmasgame
    A boolean is just the name for a variable with two states. In flash this is true and false.
    Just try what I said.
    You know how to make a variable right?
    var isJumping:Boolean = false;
    (on the main timeline).
    So, there are 3 frames in the player movieclip, and animation movieclips inside those frames of the player?
    Did you try WitchXHunters' code without the 'do something' bit?
    Apr 24, 2012 7:33 AM   in reply to xmasgame
    you're welcome .^^
